8 Rib Leftcoast32 setup
#31
Thanks!!
Yes I was 12 psi before , I need a go pro for sure !
Yes the IW pulley presses on like the stock one, although I needed a longer tool tool to seat it and a couple extra fender washers, I used a tool Pat made out of all thread, can't remember the size at the moment.
Well the water pump nut is cosmetic for us because I welded our water pump pulleys, which I recommend anyway on a belt drive blower setup as you guys know already.
#32
#36
Yep, the IW pulley is two piece , it has a hub that presses onto the crank, which can be pinned like a stock crank, and has a key way machined in for the outer pulley to slide over, it's been about two years roughly since I've installed it, I try to find pics and my memory is **** haha.
#37
Everything looks great! Thanks for the pictures and all the help from both of you (Pat and Tim worked with us to dial in the package to make it an easier bolt on for ll the members).
The Lc32/T-Mac pulleys are a work of art. I am so glad that Tom is part of the team, he is an Engineer, Enthusiast and a Perfectionist!
Thanks for the great support!!
#39
LS1Tech Sponsor
Looking good Tim, I like the video.
Next step will be a cog belt just to see how fast he can spin the blower!!! I know you will not be happy running 11.3s lol.
We will have to cruise the 64' Olds when you head out here.
