700hp possible?
Alright so Ive upped my goal with the truck and trying to see if this combo would work.
Trick turbo kit 76mm journal bearing
LS6 heads(P&P w/ bigger intake valves and maybe bigger exhaust valves)
LS6 cam
ARP headstuds with LS9 gaskets
Keep NNBS truck intake and put 92mm TB
Upgraded fuel rails w/ 90lb injectors
Twin Walbros or 304 Aeromotive pump w/ hot wire kit on either
4" DP w/ 4" exhaust
Is this going to get me close to 700hp at the ground? Will be ran through a built 4L80E into a custom Currie 9" with 4.10 gears and 35" tires
LS6 cam
4" DP w/ 4" exhaust
i was gonna ask what motor this was on. is it a 4.8L? the goal is very possible, depends on what kinda boost you'll end up running too. is this being done to the truck in your sig above?
