6 Lbs of boost is not enough
Old Dec 27, 2007 | 05:08 PM
  #51
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Originally Posted by trever1t
Let me see if I understand you correctly
I'm actually running richer than the gage displays if I'm injecting meth into the intake?
Yes, but not by a heck of a lot. The big amount I show up there is the outside edge. Even the 50/50 mix will be more than 99% of all the cases out there (the examples are with 2 15 gph nozzles spraying at capacity).
Old Dec 27, 2007 | 05:11 PM
  #52
trever1t's Avatar
2nd fastest 5.3 ECSB
You should post this up in the tech only section too. Good info.
Old Jan 22, 2008 | 12:05 AM
  #53
vanillagorilla's Avatar
Originally Posted by TurboBerserker
1. we need is the amount of meth by volume compared to the gasoline. For this example, lets use my truck -- two 15gph nozzles feeding meth and 139lbs/hr (96@43.5 + a 1:1 boost ref'd FPR at 18psi). To get g/h, divide by 6, so I'm pushing 37 gph. Keep in mind that only 1/2 of the meth is actual fuel (meth = 50% methane 50% oxygen) so of the 30gph we're pushing, 15gph is fuel.
Not to bring up an old post, but I'm not following your calculations here.
You have 8 injectors rated a 96lbs/hr at 43.5psi. At 18psi boost you should see roughly 61.5psi rail pressure at which case your injectors are now flowing 114lbs/hr. That's 912lbs/hr total or 152gph of fuel.
Now you have 2-15gph nozzles flowing 100% meth, with meth being 50% oxygen. So you have 15gph of methanol, which leaves you with a ratio 15/152=.1 or roughly 10% meth. Crunching more numbers says that you should be shooting for 11.45:1 AFR when targeting 11.5:1 AFR without meth.
Correct me if I'm wrong, but that doesn't seem like a big difference to me.
Old Jan 22, 2008 | 06:13 AM
  #54
I AM A MOTHERF*CKER
Remember that the trucks run on 4bar of fuel pressure, so the 96ers aren't starting at 96lbs (so we have to first convert to the 58psi base pressure, then add 18psi = 76psi).
I'm running late, so I'll have to try to get back to this post
Old Jan 22, 2008 | 08:13 AM
  #55
Right, I thought you were running a 3bar setup since I thought you're running Megasquirt. It just seems counter-intuitive that you're replacing gasoline with another fuel that has a lower stoich value, and you're target AFR is higher on the guage.
Old Jan 22, 2008 | 09:07 AM
  #56
I AM A MOTHERF*CKER
Yes, at first glance, it does, but think about it this way:
you are now trying to measure the lambda of a fuel with a lower stoich than what the gauge is calibrated to, so the gauge will read higher than the actual lambda.
Old Jan 22, 2008 | 10:13 AM
  #57
So at 58psi plus 18psi boost you have 76psi rail, that equates to ~126lb/hr per injector. That's 1008lb/hr total and 168gph.
15gph of meth with 168gph of gas. 15/168=.0893 or 8.93%
8.93% meth and 91.07% gas
.0893*.93*6.4+91.07*1.07*14.7=14.86 mix stoich
14.86/14.7=1.011 gauge calibration discrepency
11.5/1.011=11.37
Old Jan 22, 2008 | 10:16 AM
  #58
dhpro's Avatar
Originally Posted by dan96z71
That is what I thought you meant....just a long day, I understand.
U shud talk with Slowhawk
Old Jan 22, 2008 | 10:24 AM
  #59
BlownChevy's Avatar
blownerator
25 Year Member
More like 40 psi at the rail....the boost pressure is pushing back on the injector.
Old Jan 22, 2008 | 12:16 PM
  #60
TrickTurbo's Avatar
Truck Sponsor
if the regulator is a 1 for 1 boost compensating it should 58psi. You may see 76psi on the rail but as BC said the boost pressure is pushing against the fuel coming through the injector. It all depends on how the regulator is set up.
