6.2 turbo build
Old Mar 31, 2013 | 08:59 PM
  #111
erikbrinkerhoff1990's Avatar
Registered User
speaking of towing with your turbo you seem pretty knowledgeable so let me ask you a question. I had a turbo on a 07 nnbs and towed with it and was seeing constant egt's of 1500 and max of about 1900. I just got a 2011 silverado and just started my turbo build. I'm turboing to tow. I was thinking of installing a meth kit to keep the egt's down (I don't want to melt my 5.3L) but you say you wont be using meth to tow with. Aren't the egt's I was seeing dangerous?
Old Apr 1, 2013 | 07:42 AM
  #112
Byrdman11's Avatar
I plan on not use meth, but if a need to I will. Your old setup sound like the exhaust house was a little small making it stay in boost all the time. Where was your egt sensor located?
Old Apr 1, 2013 | 12:00 PM
  #113
Registered User
It was a sts remote mount turbo and when towing I could get full boost by 2000rpm all dependent on how far my foot is in the trottle. But I live in the rockies so im always going up and down steep grades. so I need the power im just a little worried about melting my engine. I placed the probe in the exhaust half way between the manifold and converter.
Old Apr 1, 2013 | 01:57 PM
  #114
Byrdman11's Avatar
Do you have to have the cat???? 1200 to 1400 degree is the rule of thumb. If it 1500 going up hill add a little fuel or pull a little timing. Meth would be good But you would need a big tank. Plus a free flow exhaust is a must...
Old Apr 1, 2013 | 07:54 PM
  #115
Registered User
I don't have to have the cats just don't really want the engine light on in my new truck. I sit about 1300 then I hit a hill and straight to 1500 then slowly climbs the longer the hill is.
Old Apr 1, 2013 | 09:07 PM
  #116
TrickTurbo's Avatar
Truck Sponsor
What's the air/fuel.
Those temps seem hi. ?
Old Apr 1, 2013 | 09:20 PM
  #117
Registered User
11.5 should I dump a little more for towing? I've also been told putting more fuel in will lower cylinder temps but up egt's becsuse the fuel will still be burning as it goes through the exhaust. Is this true?Any advise is welcome I don't want to ruin my engine but need the power around here.
Old Apr 1, 2013 | 09:32 PM
  #118
Byrdman11's Avatar
I would start by remove the cats to get that hot gases out of there.
Old Apr 1, 2013 | 10:19 PM
  #119
Registered User
Correct me if i'm wrong but with the turbo after the cats they shouldn't matter right? Because the turbo is the most restrictive part of the system the cats aren't to restricting where the turbo is after them.
Old Apr 2, 2013 | 06:55 AM
  #120
Byrdman11's Avatar
I was thinking you had a front mount. Sorry.. I didn't read....Im not sure about being in front the turbo. I only build and run front mounted systems. But I would think being in front of the turbo 1500 is not bad.
