6.0 + d1sc = ????
Old Mar 21, 2010 | 09:46 PM
skeet's Avatar
Originally Posted by danbap
yeah i dont want to be on the edge right now. so 600rwhp will be kinda safe? how much boost do you think it would take to get there?
thanks skeet hes running a lq4. i havn't found many guys running with the lq9 and a d1sc.
true, my bad dunno why i was thinking lq9, myself its crossed my mind about getting a D1 just hadnt brought myself to do it yet, since the truck is running low 11s NA then fixing to run some juice through it, probably sometime next year i'll change the whole setup and try a procharger
Old Mar 21, 2010 | 10:51 PM
TurboGibbs's Avatar
So many variables...
LQ9 has 10.5:1 compression. That will limit your "safe" levels. I'd say 500-550rwhp could be safe with the proper cam and tune on 93 octane. If you add meth injection, then more boost and timing could get you more.
Old Mar 22, 2010 | 03:28 PM
allballz57's Avatar
I believe the LQ9 is 10.1:1 not 10.5:1.
Old Mar 26, 2010 | 09:07 PM
danbap's Avatar
you guys running the 6.0s are any of you running a stock cam? if not what cam are you running?
Old Mar 26, 2010 | 09:17 PM
Most Hated's Avatar
im running on 14 psi p.g custom cam lq4 i use to have an lq9 on 150 nos but cracked piston #7 too i seen alot of lq9's do that i wonder if u swap the pistons only if that would work
Old Mar 26, 2010 | 09:20 PM
Dusty05's Avatar
I'm running a 224/224 on a 114...not really an ideal boost cam but at the time I installed it I was not not expecting to run boost...I started a post on the epp cam and the thunder racing cam....
Old Mar 26, 2010 | 09:30 PM
danbap's Avatar
ok, im asking because im trying to stay on a very tight budget and when i add in a cam $400, ati balancer $475, plus i still have to get the 8 rib pulley which is $250 its adding up FAST.
Old Mar 26, 2010 | 09:35 PM
Dusty05's Avatar
You might want to have a cam spec'd out for you.... it gets expensive really quick though!!!!
Old Mar 26, 2010 | 09:40 PM
danbap's Avatar
i already have the patriot dual gold extremes. and i was already planning on pushrods. did you ever run the stock cam? how much power has some one made with a stock lq9 or lq4 with only valve springs, and rod bolts?
Old Mar 26, 2010 | 09:44 PM
Dusty05's Avatar
Oh ok....I never had the stock cam with the procharger but it will "work" kinda like my 224/224 lol.... just leaving alot of power on the table....
