5.3 or 6.0 or 6.2 + Boost ???
Old 06-12-2012, 03:24 PM
10 Second Club
GONEB4U's Avatar
Default 5.3 or 6.0 or 6.2 + Boost ???
Here is my dilemma, I currently have a 6.0 L76 in my 07 Vortec Max. I will be adding a Trick Intercooled turbo kit to it VERY VERY soon. I have a 2011 5.3, the 6.0 in my truck and a 2011 LS3 on the engine stand. Here is what I will do to any of the above engines. I'm looking to add a LS9 cam, delete the dod and vvt on the 6.0 or 5.3. Add ARP head bolts and re gap the top piston rings to have a .028 gap from stock.
(1) Do I swap out the 6.0 for the 5.3 with a 66mm or 76mm turbo?
(2) keep my 6.0 with 76mm.
(3) Swap in the LS3 with the 76mm.
I will be also swapping the 4L70 for a 6L80 that I already have. My truck came with 3.73's from the factory so I was thinking maybe the little 5.3+BOOST will be fine. Any of the above will be tuned and will be always be running on 93 octane cause this will be my weekend truck. I will be running 1LB less boost then it can handle with the 93 octane to have a little margin of error on any of the above combos. I am not looking to run Meth. I'm leaning towards the 5.3LC9 or 6.2 LS3 to cut out some down time cause I can do all the mods to it and just swap it in the truck in a day.
Which would you choose and why?
Old 06-12-2012, 06:03 PM
03sierraslt's Avatar
Ok first question, why a LS9 cam? Second if you don't use the LS3 then what will you do with it?
Old 06-12-2012, 06:38 PM
10 Second Club
GONEB4U's Avatar
I already have the LS9 cam. The LS3 is my spare engine for my 69 Camaro and is NOT forsale if that's what your getting at.
Old 06-12-2012, 07:04 PM
Byrdman11's Avatar
I like the ls3 with boost idea.
Old 06-12-2012, 07:08 PM
No thats is not what I was getting at, just trying to get a better Idea of your situation to make a suggestion. Personally I would use the 6.0.
Old 06-12-2012, 07:09 PM
Ferocity02's Avatar
Biggest question is what are your power goals?
Old 06-12-2012, 07:32 PM
Save the LS3 for you Camaro, do the mods to the 6.0 and save the 5.3 as a backup. As others have mentioned what are you power goals?
Old 06-12-2012, 08:10 PM
TURBHOE's Avatar
And why swap out the 6l80e? That 4l70 will be toast in no time.
Old 06-12-2012, 08:22 PM
10 Second Club
GONEB4U's Avatar
Sorry but I already received 2 pms asking me to sell them my LS3 if I'm not going to use it. I'm shooting for 500whp minimum to 600whp max. I'm starting to lean towards my 6.0 in the truck and my tuner suggested that I leave the rings alone at these power levels. What do you guys think?
Old 06-12-2012, 08:35 PM
At those power levels the rings will be fine and the 76mm should work good. Do you have the full specs of the turbo?
Quick Reply: 5.3 or 6.0 or 6.2 + Boost ???
