416 stroker turbo
Old Nov 29, 2015 | 06:19 PM
  #21
caviness's Avatar
also I know ill need to change the gear to but what to , its my daily but that's only about 50 to 100 miles a week normally so I might lean a little more towards the track on the gear , ill be running 20s on the street and if I go track ill be getting me a bogarts setup on 16 and 15s
Old Nov 29, 2015 | 06:23 PM
  #22
caviness's Avatar
Thanks for all the info so far. the turbo stuff is new to me on cars and trucks but know a little about my big trucks I got with 60 series Detroit I run BW 171702 on them to keep the exhaust free flowing but they boost around 40 psi
Old Nov 29, 2015 | 06:27 PM
  #23
caviness's Avatar
the motor that's in truck now was in my Camaro and it run 6.60s on 150 shot and 7.30s on motor so the truck eat up a lot of that just taking the motor and trans out of car and putting in truck lost a lot of get up and go.
Old Nov 29, 2015 | 06:30 PM
  #24
caviness's Avatar
on the convertor I can send that back and get it restalled or get another one
Old Nov 29, 2015 | 06:33 PM
  #25
caviness's Avatar
George c , Atomic thanks I been reading a lot of yalls builds and stuff bad *** trucks for sure
Old Nov 29, 2015 | 07:51 PM
  #26
silver-mod-o's Avatar
Hunt&Fisherator
I'd consider a T6 kit from KBRacing. You can still run a medium frame turbo (even with a T4 adapter if needed) and have the hot side already there if you wanted to upgrade down the road with a bigger turbo etc. this way, the kit is purchased once and you're done.
Old Nov 29, 2015 | 08:30 PM
  #27
caviness's Avatar
sounds like nice kit
Old Nov 29, 2015 | 08:40 PM
  #28
TrickTurbo's Avatar
Truck Sponsor
Give me a shout to go over your build and your requirements.
940/781-5204
--I recommend Being realistic on your goals.--
Many assume people want more later in life because they wanted more.
While others build for 1000+ hp but never get there or run out funds else where.
Then that kit is too big and just a big giant POS on the street.
Kit should be built to match the goals and have the ability to upgrade with ease when the time is right.
Old Nov 29, 2015 | 08:50 PM
  #29
caviness's Avatar
Thanks ill give you a call later this week
Old Nov 29, 2015 | 09:29 PM
  #30
Atomic's Avatar
I have a gauge for that
Pretty much sums it up right there. A lot more goes into building a 1000hp truck than just turning up the boost controller. Even 800 is rowdy on street tires in a truck, not something to be taken lightly.
The s400-84/96 sounds like it might fit the bill for what you want though, will spool decent on the street and make 1000hp on your motor with it turned up.
