4.8 turbo
Old Feb 1, 2015 | 06:35 PM
Byrdman11's Avatar
For the mid mount for sure.
Old Feb 1, 2015 | 09:29 PM
LostInTheSauce's Avatar
Originally Posted by GMCtrk
S475/83 is way too much turbo on a 4.8 for his goals. For what he wants, an S366 would be my choice - optimum combination of power potential and spool.
sorry, got side tracked watching Seattle blow the game on the one yard line
But thank you i will definately look it up. would anything else change being that it is a mid mounted turbo? Would it be best to get a cam off the shelf or should I get one cut? I read somewhere that turbo set ups require a different kind of cam.
Old Feb 1, 2015 | 10:36 PM
Byrdman11's Avatar
Keep the overlay down and you will be golden
Old Feb 2, 2015 | 01:00 PM
kbracing96's Avatar
What you want for a mid mount and will mostly likely fit your pipes (T4 inlet, 3"vband outlet) is a Precision PT72/68. .96 a/r will be fine for there.
If you really cheap, then go with an On3 T70 with .96 a/r.
Old Feb 2, 2015 | 05:27 PM
black4.8's Avatar
I got over 600whp out of the mp70 on a stock bottom 4.8. kb racing kit, 221/221 lunati cam. lot of guys love the triple 12 cam. s475 is overkill for 500hp. my mp70 will probably be up for sale within the month.btw
Old Feb 4, 2015 | 06:21 PM
03chevytruck's Avatar
How much boost did you have to run to reach the 600 mark black4.8?
Old Feb 5, 2015 | 06:51 PM
black4.8's Avatar
it peaks at 16# at 4500rpm. that's all that little turbine wanted
Old Feb 5, 2015 | 07:35 PM
I'm good with that for a starting point before I pull the 4.8 and upgrade turbo!
Old Feb 5, 2015 | 08:33 PM
Choda's Avatar
Love my 70mm on my stock 5.3
Old Feb 20, 2015 | 06:27 PM
Blackrat48's Avatar
Mine is a bw s366 66mm .91ar 2.25" in 3.5"downpipe dumped behind cab
Running 10psi for now....have only drove it bout 150 mi after tune and very good street manners...and havent got it on a dyno but im pretty happy...sounds awesome too...
Prolly being laughed at for havin that small of a turbo lol
But i sure like it...
Pretty confident that its over 450hp...
