4.3l Turbo Question
Well Ive got a 5.3l RCSB silverado as a daily but after thinking it over it seems more cost effective and less risky to boost my bagged beater S10.
Its a 2000 with the 4.3l 5spd. Ill be building the headers myself, running an intercooler and will suppliment fuel with a pair of extra injectors, still undecided on tuning.
Ive done some searching and can seem to find much info about the size of the turbo I should run for a front mount. I know alot of guys on here are godlike with turbos so I figured this the best place to ask.
Thanks
Thanks
Try this guy....
http://www.s10forum.com/forum/f11/sy...e-pics-309417/
Be careful on that site they are like a bunch of pirahnas if they hear a dumb question they will ride you like an old mule. Also my own shameless plug....
http://www.s-seriesforum.com/forum/s...ad.php?t=80836
you'll have to register to see anything, dumb I know but a good site.
Thanks for the links, yeah i know about s10forum...been a member there for over four years....mostly just lurk because like you said....90% of the members are there to just flame others.....there is a nice buildup over there of a front mount turbo that ill be following but i cant seem to find what size turbo I need. Its just a little confusing to me, I understand the build and tuning aspect but not turbo size
http://www.turbobygarrett.com/turbob...ch_center.html
you could go smaller but i did the leg work to TT my 305 to about ~500fwhp
and to do that i would need two of these GT3071s
http://www.turbobygarrett.com/turbob..._700382_20.htm
off hand gues running a single gt37 would put you ~300-350 if you maxed the turbo out around ~35psi spool would be really good tho
just my .02cents
I hope I am not breaking the rules here, if I am forgive me, I am just trying to help out: www.syty.net.
i would definitely check the syty forum over the S10 forum. most of the guys on the S10 forum are ******* retards, and shouldnt be looked to for helpful advice. a stock turbo on a syty is a little smaller than a mitsu style 20g. a large t3/t4 would work pretty well. if you want, you can even buy aftermarket headers for a syclone, and use them on your truck. or, if you can find them, a set of stock syty manifolds. beware though, the syty guys think they are made of solid gold. good luck!
Thanks for all the input guys.....I found somethin on the V6 site posted above....was talkin about a t70 turbo from master power......after checkin it out it looks a little large......however people are running it on the 3.somethin camaro motors so I guess thats somethin to look into
Dave
