20psi on stock 4.8
Old 05-15-2012, 08:56 PM
  #21
foose04's Avatar
Damnit son.... Really sorry hear that. Sounds like she detonated pretty good on that spike... Seems like a waste gate problem that costs someone a lot of money gets posted every 60 days or so....
Sorry man, if you was close to Charleston I'd help with pullin it. Take a break, cool off , and keep your head up.
Old 05-15-2012, 09:10 PM
  #22
jjc839's Avatar
I guess my next question is, which years are a straight up bolt in (2001)? Would like to stick with 4.8 or 5.3, this turbo is too small for a 6.0. I would like to stick with my current PCM as it already has the blackbear tune. Which years have the same fuel setup (return/returnless)? Thanks guys.
Old 05-15-2012, 09:13 PM
  #23
I have a gauge for that
Atomic's Avatar
Sucks to hear man...
Your pcm and fuel system can work with any of those engines, but you would need a retune for a 5.3 or 6.0
Old 05-15-2012, 09:32 PM
  #24
lglowe's Avatar
Holy sh!$batman. Sorry to hear that. You can just your existing intake manifold on whatever engine you pick up. It would be nice to head stud it along with some ls9 gaskets before it goes in too. Would be handy if you decided to go 15-20 psi later on.......... Again ha
Old 05-15-2012, 09:51 PM
  #25
GFYS and STFU
Spoolin's Avatar
Any of the motors will work with your current parts. All you would need is a different tune if you go up in displacement. Also the turbo can work on the 6L, you'll just be running less boost. It will make the same power since it will flow the same amount of cfm's, you'll just have more low end torque.
Old 05-15-2012, 10:02 PM
  #26
ak2007r6's Avatar
Really sorry to hear man, thats a major bummer. I hope you find a good deal on a motor and can get it all going quickly. 4.8's are pretty common and can probably find one pretty easy I would think.
Old 05-15-2012, 10:56 PM
  #27
jjc839's Avatar
There's a 120k mile 4.8 just an hour away for $500, says its 155-160 compression, I'll likely go that route. I'll use a 5.3 if I can find one quickly, but 6.0's go for a premium up here from what I've seen. I'll keep you guys posted, thanks for the support.
Old 05-16-2012, 03:09 AM
  #28
TimDave217's Avatar
yep sounds like my story... my motor sounded fine checked compression three of them were bad. i feel for you man hope it can get back up and running quickly.
Old 05-16-2012, 10:28 AM
  #29
kbracing96's Avatar
Try to find an 05 or newer motor. They have stronger rods in them. Sorry to hear about your misfortune,
Old 05-16-2012, 11:36 AM
  #30
fortplainman's Avatar
dang that sucks to hear but live and learn. you now have an excuse to work on the motor before the swap is done though. in for updates.
Quick Reply: 20psi on stock 4.8
