2010 5.3 turbo suggetstions???
Old Mar 9, 2013 | 12:31 PM
urdone's Avatar
Default 2010 5.3 turbo suggetstions???
What should i do next to my truck? I got a 2010 single cab gmc 5.3, trick performance 76mm kit on 7lb's with 3 inch exhaust.
I was thnking to buy a cam and bump it to 10 lb's and at the same time i want to drop a 6.0 on her, but im thinking twice to take off the 5.3 and just install a cam to it.
What you guys recommend to me?
Old Mar 9, 2013 | 01:28 PM
ak2007r6's Avatar
ARP head studs, cam, springs and up the boost
Old Mar 9, 2013 | 02:03 PM
urdone's Avatar
What cam you recomend?
Im going to take this 5.3 to the max.
Old Mar 9, 2013 | 02:27 PM
TrickTurbo's Avatar
Truck Sponsor
Yea. Run the 5.3 tell it gives out.
Go ahead and up your final exhaust 3" is gonna start holding you back.
Old Mar 9, 2013 | 03:14 PM
ZO6Ted's Avatar
There are a ton of cams that will work well but just to keep it simple and reliable and still run its *** off... Isky triple 12 and start turning it up! The 5.3 has plenty of potential!
Old Mar 9, 2013 | 03:18 PM
urdone's Avatar
Where can i find the Isky triple 12?
Old Mar 9, 2013 | 03:21 PM
53bowtie's Avatar
Contact Jarrett (stock48 on here) and he will set you up!
Old Mar 9, 2013 | 03:22 PM
supercharged680's Avatar
hows the 76mm on that little 5.3? lots of lag?
Old Mar 9, 2013 | 03:23 PM
CrustyWeasel's Avatar
are you still running 4l60? I would have a custom cam made to your specs get head studs and springs and turn up the boost. my friend was putting 800+ to the wheels with 3'' on his 5.3 he upgraded to 3.5 recently.
urdone's Avatar
Thanks guys...
53bowtie i will contact him thanks.
