2004-2006 FORD F-150 Supercharger Systems!! New Info Inside!!!
Old Oct 2, 2006 | 04:09 PM
BlownChevy's Avatar
blownerator
25 Year Member
Default 2004-2006 FORD F-150 Supercharger Systems!! New Info Inside!!!
• Air to water intercooled supercharger system includes the intake manifold intercooler core, secondary radiator, coolant reservoir, coolant circulation pump and all necessary wiring harnesses, hoses and clamps.
• Cast aluminum manifold replaces factory nylon intake.
• Magna Charger 5th Generation MP112 supercharger with integral bypass valve. Same internal rotating assembly as, Jaguar, Ford Cobra, Lightning and Harley Davidson Truck for extended service life and quiet operation.
• Internal bypass valve reduces parasitic losses while cruising for increased efficiency and economy.
• CARB EO# 488-11 has been granted from the California Air Resources board, making this an emissions compliant supercharger system.
• Fuel system includes new fuel injectors, factory “push lock connectors” and computer re-programming for optimized drivability, and fuel mileage.
• System comes complete with all necessary brackets, connectors, hardware and fuel system components including fuel line disconnect tools.
• Instruction manual is complete with color photographs and is extremely user friendly with easy to read text.
• Standard 3-year limited warranty on the supercharger system.
• Hand Held tuner for uploading calibration.
Radix Intercooled F-150 5.4L 3V Trucks & SUVs
01-12-65-051-SL 2004-06 Ford F-150 Silver $5,000.00
01-12-65-051-PO 2004-06 Ford F-150 Polished $6,000.00
We are a Stocking Magnuson Supercharger Distributor (while supplies last). We have all truck systems in stock and will not be beat in service ! There is a reason we are the NUMBER ONE Magna Charger Dealer in the USA! We will match any of the competitions prices with 25% back to you on the difference.
05GMC4.8
Aug 7, 2015 09:55 PM
gtyler04
Jul 28, 2015 06:21 PM
carid
Jul 24, 2015 05:00 AM
FlowmasterMufflers
Jul 22, 2015 01:29 PM
FlowmasterMufflers
Jul 22, 2015 12:47 PM
