2 bar map ?
anyone on here using the dash daq I'm thinking of getting one and was wondering if i want to see afr and boost on it do i need a 2 bar map? and why? Sorry still kind of a newb
A 1 bar map only goes to atmospheric pressure, no positive pressure (boost) readings. The 2 bar will allow your gauge or you to see past the 105kpa. If you change your MAP that your pcm uses, then you will need a new tune as well.
calsdad
Jun 14, 2023 11:07 PM
carid
Oct 1, 2015 09:22 AM
