15 Silverado 6.2L TVS2300 Belt Drive Help
Old Sep 14, 2016 | 11:40 AM
r44guy's Avatar
Registered User
Originally Posted by Blown06
Yeah you definitely need to move some idlers around or something. That looks like 50% or less on the belt wrap. If you can get it closer to 70%-80% it should make a big difference.
I imagine that you could work with Innovators West and Joe @ Leftcoast32 and yall could get an 8 rib conversion knocked out. May take some trial and error........but if you can get it figured out first......you'd be the man.
Blown06, Yes I have talked with IW & LC and they both have this on the non priority list and so far no one has any answers for help but I am still trying. The only help so far is a company that will make a pulley with some other traction groves cut in it for the TVS2300.
Old Sep 15, 2016 | 02:34 PM
SleeperGMC's Avatar
Contact Brian at Superchargers Online and get one of the Griptec pulleys for now. I know it's not the long term solution but it should help for now until you can figure out another solution. I had some pretty bad belt slip on my 2300 and that pulley fixed my issue...for now.
Old Sep 16, 2016 | 09:20 AM
r44guy's Avatar
Registered User
Default GripTec to the rescue
Yesterday my package showed up with the new Grip Tec pulley and to say the least I was very impressed with the amount of traction incorporated or laser itched into the design of the pulley.
Old Sep 16, 2016 | 09:49 AM
ZO6Ted's Avatar
Wondering if there is any increased belt wear with that type of pulley. I'm not getting any slip but wondering if I should consider this with Atomic's adapter for my pulley down soon?
Old Sep 17, 2016 | 02:35 AM
Blown06's Avatar
8 Second Truck Club
Could you please post up a pic of that pulley?
Old Sep 17, 2016 | 09:36 AM
r44guy's Avatar
Registered User
Please see the link below for additional pictures.
GripTec® micro
Attached Thumbnails 15 Silverado 6.2L TVS2300 Belt Drive Help-griptec-micro-l3.png
Old Sep 17, 2016 | 10:37 AM
07Softail's Avatar
I sand blasted my pulley not sure how it will do yet.
RT
Old Sep 17, 2016 | 02:03 PM
r44guy's Avatar
Registered User
Default Forward Progress
After the new GripTec Pulley install the and new CAI set up I am now holding about 11PSI of boost and the dyno numbers look good until I ran out of fuel pressure at about 6000 RPM's on E85 even with the secondary fuel pump set up with all of the LT4 fuel system. Time to mix some E85 and 93 and retry next week. (Yes I have upgraded the DI system to the LT4/Z06 high pressure fuel pump, fuel rail lines, & Injectors before the aftermarket aux. fuel pump was installed. The stock torque converter shudder is bad with over 650 ft Ibs of torque. Needless to say I will also be installing another upgrade this week.
Old Sep 17, 2016 | 03:51 PM
07Softail's Avatar
How are the vette guys making way more power with the LT4 DI setup....and the L86 Truck wont get close to there numbers even with the LT4 DI pump upgrade? Any ideas anyone? Tank pump not keeping up.
RT
Old Sep 17, 2016 | 06:12 PM
r44guy's Avatar
Registered User
RT
RT, From what I have seen my numbers are close to the Z06's. Here is what my truck made on the dyno today 666whp and 670ft/lbs on 10 psi. On E80 running out of fuel. It sounds like I can pick up at least another 20-30whp left in this one with e50.
Attached Thumbnails 15 Silverado 6.2L TVS2300 Belt Drive Help-15csdp1.jpg   15 Silverado 6.2L TVS2300 Belt Drive Help-15csdp2.jpg
