10 sec pass on my 5300 Lbs truck
Old Dec 19, 2014 | 01:39 PM
  #21
boostedsl2's Avatar
Originally Posted by 05gmcsierra
I'm running a custom cam made by ryne at Cunningham Motorsports 230/236 116+5
I'm running 17x9.5 racestars with m&h 275/50 radials
awesome. Thanks for the info.
What kind of backspacing/offset? sorry for the 20 questions, I'm trying to make a decision on what to get myself. Seems like the a 275 is the answer for a tire, but I can't decide between wheel size. mostly due to the fact that the backspacing is too little and would push the tire into the fender.
Your truck looks good with that tire. That is another concern is the nicer tires all have a 26" or lower OD which ends up making the truck look like a clown car haha.
Either way, congrats!
Old Dec 19, 2014 | 06:41 PM
  #22
TimDave217's Avatar
awesome run man! that thing is hooking with a 1.4-1.5 60 ft. I'm almost baffled that it is getting those kind of times in the 60. Are you still stock suspension other than what's required for lowering???
Old Dec 19, 2014 | 06:59 PM
  #23
cpolaris502's Avatar
I'm interested in the suspension also. 14bolt swap? My goal is to be in mid to low 11's some day soon.
And yes, I weighed my truck a few months ago. Right at 5k lbs, spare tire, hitch, everything stock and then some.
Old Dec 19, 2014 | 07:11 PM
  #24
GMCtrk's Avatar
With what you have in your sig, you should definitely be in low 11s.
Old Dec 19, 2014 | 07:46 PM
  #25
Good to hear. Went to the track once last summer (first season on boost) and best was 12.8/123mph. 2wd, stock G80 3.23, cheap street 20" tires. Best 60' was 2.4! Slicks and 14bolt is in my future.
Old Dec 19, 2014 | 08:39 PM
  #26
GMCtrk's Avatar
Those gears are killing you and so are the street tires. I would go full slicks on 2wd. Even my 315 drag radials are a handful at 800 hp. The 10 bolt should be fine until you get into the 9s.
Old Dec 20, 2014 | 04:20 AM
  #27
05gmcsierra's Avatar
Suspension is bone stock AL I have are lowering belltech street performance shocks and caltracs... I was spinning fronts so I'll be strapping down next time.
Old Dec 20, 2014 | 09:10 AM
  #28
TimDave217's Avatar
Must be nice to have 4WD. I always contemplate converting my truck over to a 4wd drivetrain.
Old Dec 20, 2014 | 10:34 AM
  #29
4WDFTW's Avatar
Same question on the back spacing? I'm going with the same setup as you witht the race stars but didn't know what back spacing to get.
Ps your truck looks bad *** and runs hard! 9s aren't that far away!
Old Dec 20, 2014 | 12:26 PM
  #30
Not sure on back spacing the only issues I have r turning my 17x9.5 front r a bit wide.. I was going to use a spacer but I just sold my rim tire set up.. going on full slicks all 4..trying to dip into the 1.3* 60' yes I'm shooting for 9s
