10-15 psi... what plugs?
Old Apr 13, 2012 | 09:31 PM
dick_landy's Avatar
I run AC 41-104 ZR1 plugs at 9 and 12 psi.
Old Apr 13, 2012 | 11:23 PM
Banned
the correct way to actually do it is put a cold enough plug to burn the cadnium off the strap, too cold and it wont burn off, too hot and it will look ashy, a 7 would take a ls motor to 800rwhp or so on gasoline, ive run tr6 heat range up to 1200-1300 flywheel hp on E85
Old Apr 14, 2012 | 12:33 AM
Blown06's Avatar
8 Second Truck Club
I think at 15 psi, it's time to at least start looking at the 7.
Old Apr 14, 2012 | 02:28 AM
TimDave217's Avatar
i was originally planning on going with the BR7EF's so now i feel better about that, what are most of you gapping them at with your boost levels?
Old Apr 14, 2012 | 03:32 PM
black4.8's Avatar
run between 10-16# and got them gapped at .028. .026-.030 should be alright.
Old Apr 14, 2012 | 06:04 PM
TIM Z's Avatar
11 sec. Truck Mod
Ive always run Tr-6 @ .035'' Never an issue.
Since its topic would the 7 be a better plug ? For Safety or Performance or both??
Old Apr 14, 2012 | 07:11 PM
03sierraslt's Avatar
For you, maybe since you are not running meth. I have a new set of non projected 6's (BR6ef?)that I am going to put in mine once I am back. I would go with a non project tip Tim.
Old Apr 14, 2012 | 08:48 PM
Swerve7rpm2000's Avatar
Bref7s.... Proven and safer imo
Old Apr 14, 2012 | 08:49 PM
LA Q-TIP's Avatar
How about the 8's?
Old Apr 14, 2012 | 11:41 PM
Blown06's Avatar
8 Second Truck Club
I had 9's in mine at 23 psi, I think 8's would have been better as the coating was still on the ground strap at 20* of timing.
My fuel was apparently off pretty bad too, so who knows.
I don't think 8's would become necessary till 20+psi
