04 turbo Silverado
Old May 4, 2015 | 03:20 PM
GMCtrk's Avatar
What kind of clearance do you have to the leaf?
It looks from the pic, that the tire sidewall and may be slightly beyond the fender.
Old May 4, 2015 | 03:26 PM
blue0453's Avatar
Tire is about perfectly flush and roughly 3/16 - 1/4" from leaf
Old May 4, 2015 | 10:05 PM
Pro52R's Avatar
What was your old turbo? And how many LBs
Old May 5, 2015 | 01:42 AM
blue0453's Avatar
Master power 15lbs
Old May 5, 2015 | 02:58 PM
04Turbo6.0's Avatar
Are you running the 15's with stock disc brakes? Did you have to grind or clearance anything? I have 16's w/ 295 50's but want to run a 15.
Old May 5, 2015 | 06:56 PM
blue0453's Avatar
S10 calipers and a **** load of grinding
Old May 6, 2015 | 05:23 PM
brandon6.0's Avatar
Hey man when u planning on dyno or track testing? I built basicly same setup as u. Just curious. Mine should be firing off in a week or two.
Clean truck by the way.
Old May 6, 2015 | 06:58 PM
blue0453's Avatar
Soon as i get the trans rebuilt its go time. Few weeks or so.
Old May 14, 2015 | 09:32 PM
Mike454SS's Avatar
How do you have your twin pumps setup in the tank? Do you have any certain fuel level you have to stay above to avoid starvation problems?
Old May 16, 2015 | 06:31 PM
blue0453's Avatar
Two 450s run to a y then a -8 bulkhead. I like to have at least half tank if im racing
