Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
Went to the Dyno today............
Old Nov 19, 2007 | 07:38 PM
closet red neck's Avatar
Here's a link to my dyno sheet.
http://i157.photobucket.com/albums/t...11907a0001.jpg
Old Nov 19, 2007 | 07:44 PM
Originally Posted by trever1t
yeah, but what does it run? Great numbers James!
Well I posted a bunch of time slips.......check out the dragracing section. The best E.T. was a 12.61e.t. @ 105.71 with a 1.78 60'.
Later that night I ran a 12.72e.t. @ 106.83 with a 1.88 60'.
I have all of my times listed in the dr racing section.
James
Old Nov 19, 2007 | 07:50 PM
Originally Posted by Z06 DREAMING
That's an impressive 5.3!
Is that sarcastic? What do you mean fine ""?
Well he asked as if it were my wife or something.......LIke "hows the wife??"
I don't know........hey Z06, hows the 2004 silverado?
Maybe I'm being a dick or just took it wrong.
James
Old Nov 19, 2007 | 07:53 PM
ZR1 DREAMING's Avatar
James
I thought he was just curious how you liked it
I want to get one also, that's why I wanted to know if you were serious about it or if you've had problems. Would you recommend it to someone else's DD?
Originally Posted by TheLadiesMan
im not sure if you thought i was doggin it. i knew there was only a couple people on here with them and i never heard any problems with them. i figured i would ask.
OK. I see. The h2o pump is working great!!! I don't want to get in to the gasket thing again with h2o pumps but I have had it on the truck for about 4mo. now and knock on wood,......the truck stays cool and it's great @ the track to cool the engine down and when you short belt the engine. just kinda pricey for pumps.
James
Old Nov 19, 2007 | 07:57 PM
James
Do you have it on a switch where you can run it at the track between laps with the truck engine off?
I'm sorry!!!!! I would use it for a DD but with everything else, electrical **** does go out. Or it seems that a machanical will go out slowly as an a electrical will just stop. That would be the only thing I would be worried about. Yes, get one!!! They are great!!! I got the polished one because they are all the same price. Make them work for their money!!!HEHEHEHE!!!!
James
Old Nov 19, 2007 | 08:01 PM
No, I just have it an ignition swicthed source. Um you could do it that way but I was just trying to eliminate the switches in the truck. I just leave the ket on for a little bit then turn it off. Then I turn the ignition on again untill the water cycles for a little bit. You need to call me and I can discuss some things with you if and when you install it.
James
Old Nov 19, 2007 | 08:07 PM
James
thanks, will do! Congrats again on the numbers man!
Old Nov 19, 2007 | 08:11 PM
bluecajun5.3's Avatar
11 Second Truck Club
great dyno #'s james!
now get that power to the ground so you can run some good times.
