Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
turbo 4.8 on dyno again
Old Oct 17, 2014 | 12:55 PM
Atomic's Avatar
I have a gauge for that
I cant see the graph, but will look later.
When you see torque peak hard then fall but power stay the same the turbo is out of breath (too far right on its compressor map). A bigger turbo would simply shift the torque curve to the right. More torque at higher rpm is more power.
When you increase boost and dont see any more power, the turbine is choked.
Old Oct 17, 2014 | 01:12 PM
black4.8's Avatar
What's you cam specs?
Lunati 221/221 .558exh/int. 112 lsa
Old Oct 17, 2014 | 03:42 PM
black00chev's Avatar
Slowest turbo build ever!
Good info!
That's a healthy cam for a 4.8!
Old Oct 18, 2014 | 05:55 PM
brent1976's Avatar
11 Second Club
Get a bigger turbo on that thing, and let it eat.
Old Oct 18, 2014 | 06:05 PM
black4.8's Avatar
Brian already gave orders to have more fuel and turbo before he see's it again. the way it sits that's all its got. maybe some winter time projects.
Old Oct 18, 2014 | 08:30 PM
One of those 76/75 turbos would be nasty on that!
Old Oct 19, 2014 | 08:31 AM
brent1976's Avatar
11 Second Club
Maybe mine will be together in the spring, and we could meet up somewhere. There is usually a spring dyno day at Brians, or maybe at a track somewhere. I didn't really get to talk to you last time we were at the dyno day at the same time. There aren't any truck guys around here, everyone has mustangs and it sucks.
Old Oct 19, 2014 | 05:00 PM
black4.8's Avatar
sounds good Brent, I plan on going to the spring dyno days. just got back from National Trails. that track is horrible. traction seems hard to come by there. Kil kare is a far better surface.
Old Oct 19, 2014 | 05:05 PM
black4.8's Avatar
btw, ran a 11.09 @ 129mph spinning and bouncing down the track. only made two passes. didn't want to put it in the wall.
Old Oct 19, 2014 | 07:35 PM
skolman91's Avatar
are you from the norwalk area? i have a couple friends with mustangs in that area and couldnt help but laugh at your statement..
