Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
street run
Old Feb 24, 2009 | 12:04 AM
regency's Avatar
something else i found! Look at the AFR!!!!!!!!!!!!!
https://www.performancetrucks.net/fo...6&d=1232474836
Old Feb 24, 2009 | 12:07 AM
95 bright teal's Avatar
Originally Posted by regency
weak for the mods in your sig!!!!
388rwhp / 390rwtq found in another one of his threads!!
Something is wrong, those numbers are way low
Old Feb 24, 2009 | 12:09 AM
regency's Avatar
yea 11.0 - 11.4 AFR ! WAY too much fuel, got me wondering if they even have enough timing put to it?
Old Feb 24, 2009 | 01:05 AM
speeedo's Avatar
how do you know the afr is 11.0-11.4 the afr is arounde 13:* to 14:* the timing is 28
Old Feb 24, 2009 | 01:09 AM
speeedo's Avatar
388 that was my old dyno the last one is 450 and 600 with 150 shot
Old Feb 24, 2009 | 01:21 AM
regency's Avatar
i must be looking at the graph while your on nitrous then because i see it in the 11 range on one and in 13 on the other line.
Old Feb 24, 2009 | 01:26 AM
speeedo's Avatar
i didnot use any nitrous shot on this run next week i will run it agine and use the nitrous
Old Feb 24, 2009 | 01:27 AM
regency's Avatar
do you have that graph, i would like to see it also!
See, you need to mention stuff like you got new #'s!! and 450 to me is still a little low, but your also going through a transfer case too.
Old Feb 24, 2009 | 01:33 AM
speeedo's Avatar
you are right i should mention sum of the new stuff but you know you can`t stop adding and working on your motore evry month theres sumthing you think about to add
Old Feb 24, 2009 | 01:49 AM
regency's Avatar
well what did you do to go from 388 to 450
