Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
Rate my setup
Old Aug 28, 2012 | 09:32 PM
CaliSilverado's Avatar
Default Rate my setup
Ive got a 99 rcsb silverado and I'm woundering what my hp trq output shld be wih what I have also any 1/4 mile est.
Sits as follows lq9 swap,223/231 115 cam, k&n cai, 1 3/4 lt headers, e fans, 8.1 injectors,msd wires, ss3200 yank stall, 4l60e with shift kit and vet servo, trutrack, 4.10s
Old Aug 31, 2012 | 02:57 PM
omar_286961's Avatar
It should be mid 13s n/a no problem and as for numbers itll be in the 350-380 rwhp range depending on the tune.
Old Aug 31, 2012 | 07:24 PM
That sounds preaty good I'm working on getting a 65e built then some more engine mods lol
Old Aug 31, 2012 | 10:28 PM
Get a 14 bolt with 4.32s and a 4l80e with a 3600 stall and you will really wake it up.
Old Aug 31, 2012 | 10:32 PM
ltr450ryder's Avatar
i would get the 80e and a 3400-4k stall 1 7/8 headers ur 4.10s will be fine and ur factory 10 bolts will be fine mines been holding up to my 408 just the built 60e died twice
Old Aug 31, 2012 | 10:47 PM
I've been told the gearing is of for me to get an 80e. I'm guessing the higher stall will counter the long first gear?
Old Sep 2, 2012 | 10:41 PM
brandon6.0's Avatar
i run 4.56s with my 80e and love them. Makes for a perfect gear ratio. Not to bad on gas either.
Old Sep 2, 2012 | 11:58 PM
What's your rpm at about 75?
Old Sep 3, 2012 | 12:10 AM
06murder's Avatar
He runs like 2600 or so brandon6.0 my cousin he has a sharp setup
Old Sep 5, 2012 | 09:28 PM
brandon6.0's Avatar
depends on tire size. Had stock 31" tire was turning maybe 2600 at 60. Thin went down to 26" tire pushin close to 3000. But this is cruising without lockup. Trans wiring was kinda off when i swapped in the 80e.
Now JB ran something like a 4.10 with his 80e and it wasnt no slouch either. Depends on setup.
