Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
post up your boosted 4.8, 5.3, 6.0 number s
Old 06-23-2012, 04:37 PM
  #31
Slowest turbo build ever!
black00chev's Avatar
And it actually helps to have a slightly restrictive(not the best word) exhaust before the turbine. Keeps velosity up and helps with spool time due to the pressure difference before and after the turbine wheel.
Old 06-25-2012, 10:26 AM
  #32
Vortec350ss's Avatar
Originally Posted by FrostKing
Turbo exhaust manifolds are not nearly as critical as supercharger manifolds because the turbo ones are pressurized. 20 psi exhaust pressure can squeeze a lot of gas through stock manifolds.
I realize that... but I think its exactly why at lower boost levels a supercharger could be more efficient. Superchargers struggle to create the boost that a turbo can, and they often cost a lot of power to create it, but at moderate boost I think the benefit of moving more air outweighs the inefficiencies of a supercharger being belt driven.
I'd be really curious to see just how much more air a TVS is pushing on a 6.0 at say 8# at 5k RPM compared to a similar turbo with stock manifold/log exhaust at the same boost level. I'm talking with the same heads, and a cam that is correctly "spec'd" for both. I know this is not because a TVS is 'better' at pushing 8# of boost, but its because so much more exhaust can escape that 8# of boost can really mean 2 totally different things there... outside of probably total air in the cylinder when it fires.
Basically what I'm getting at is I think I'm realizing for a low boost aplication, like my LQ9, a supercharger might be a far superior answer to create great power using FI...
I'm sure there is something I'm missing about a turbo set up that will even everything out here... and I really want to understand this. I think the bottom line is I may not have enough of an understanding of what makes a turbo set up great while I am much more familiar with a blower. Everythign I typed makes sense in my head, but I'd love to be proven wrong lol.
Old 06-30-2012, 04:51 PM
  #33
I'll add this to the mix. I don't know who this is... but I have a feeling they are a member here.
Those are real impressive numbers on 10# in a cam only 5.3. Add a little displacement for a 6.0 and a 76mm turbo and that looks like a 600 RWHP dyno at only 10#. Pretty awesome.
Old 07-05-2012, 01:04 AM
  #34
matthimself's Avatar
397.81 RW/HP 446 RW/TQ SAE Corrected.
LQ9, LS6 Cam, Mid Length Headers, Cats, Radix MP112, 3.4 Pulley, 42lb Injectors, Walbro 255lph in tank, EFI Live base tune (Black Bear).
Hope to do a little better once I send back data logs plus I swapped out the crappy flowmaster 40 as well as some more mods to come.
Old 07-17-2012, 05:21 PM
  #35
The flow 40 is probably hurting more than you think.
How much boost does that pulley get you? It can't be much.
Old 07-19-2012, 08:30 PM
  #36
Kameron's Avatar
That's Carbongmc, a member on here. The 5.3 melted a piston a few months back and a new build is in the process!
Old 09-13-2012, 08:12 AM
  #37
Banned
Yea I understand that, but its definitely something worth noting. The turbo's are much more efficient at making boost... theres no question there, but without spending an arm and a leg on a turbo kit they still use the stock manifold on one side... kinda whacky if you ask me. Just by looking at most of the kits I think there is a ton of power potential left in them... look at how much boost supercharged guys lose when they go to a great exhaust system... yet they are stil pushing as much if not MORE air through the engine.
I use two stock 6.0 manifolds on my camaro and make over 1500 rear wheel hp. so dont worry about the manifold being the restriction. turbos dont dyno good, they have to spool and the numbers will always be off because its a short pull,
Old 09-21-2012, 12:24 PM
  #38
La Chochita's Avatar
Patrick g cam (spec'd for procharger), comp cam single valvsprings, stock heads, stock intake, stock tb, stock head bolts, stock mains and rod bolts.
Pt 88 turbo 16 psi/20psi second pull
Snow Performance methanol
No NOS (hate it)
4l80 w/4400 circle D verter with circle D flexplate.
Dynoed on 20's 295/40's
Recently chipped piston #3 due to the stupid vacuum line melted from waste gate.
On a Loaded dyno:
671rwhp/622rwtq @16 psi..........792rwhp/680rwtq @ 20 psi......
16 psi pull
20 Psi pull
Old 09-21-2012, 09:49 PM
  #39
milkey57's Avatar
Thing sounds like a damn jet takin off!!! Bad *** numbers too!
Old 09-21-2012, 10:38 PM
  #40
lglowe's Avatar
Bet its laggy as **** on that 4.8! But dam its like the space shuttle when it lights off LOL... Awesome
Quick Reply: post up your boosted 4.8, 5.3, 6.0 number s
