Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
not happy with numbers
Old Sep 26, 2006 | 01:24 AM
thunderwagen's Avatar
your numbers can change from one dyno to another so i suggest using the same dyno everytime. Altitude and things like that play a big part in it too. My LQ9 put down 244 stock. A lot of people get better numbers than that. Remember a dyno is just a tool to help you tune and measure how much you gained going from one set up to another. If it is running good and you are putting the spank down on the guy next to you that is what matters!
Old Oct 4, 2006 | 03:23 AM
jblack6527's Avatar
Originally Posted by gnd111
Gearing should have no bearing on output numbers. If you put 3.73's it should read the same a 2.96's or 4.88's...
That's what I always thought, until I read a dyno test with a mustang, going from 3.73 to a 4.10, they lost like 7 hp... I guess it's kinda like the fact that an automatic will dyno higher torque numbers than a stick, because of the torque converter..
Old Oct 4, 2006 | 10:39 AM
but an automatic will also dyno lower HP numbers
Old Oct 30, 2006 | 06:50 PM
NegraRCSB2X4auto's Avatar
who cares just race someone who has about the same power as you which sounds like stock truck just like yours. if you beat them then you know you have more than that paper is telling you and just burn it after you win.
thompson
Dec 27, 2017 06:48 AM
cheyenne383
Nov 13, 2015 09:24 AM
Gadgetized
Oct 22, 2015 09:06 AM
KleanKustoms
Sep 30, 2015 05:07 PM
