Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
New Dyno #'s with new cam, VID included
Old Jan 10, 2009 | 09:44 PM
fastrt's Avatar
11 Second Truck Club
nice gain from the ***** cam that you had. lol. good luck with the heads.
Old Jan 10, 2009 | 09:54 PM
forbes's Avatar
<~~the guy with the stock rst..
hey man good to see ur run...
i started makin calls on mills today thanx to u guys.
problem is i am an old carbby ford guy, and dont understand half of the stuff ya'll talked about..
but plan on pickin ya'lls brains soon... i'll go see LG motorsports over here in wylie..
thats who does my dads builds.. see what he has to offer.. then plan on buggin the hell out ya'll
Old Jan 10, 2009 | 10:36 PM
53RUSSELL's Avatar
Originally Posted by BlackGMC
thanks, that was with the cutout open, but I run 2 magnaflows in series.. both 1 round 3" 5X18 and 1 oval 3" 5X9X18 ( i think those are the specs)...
Did do runs with cutout closed to see if the tq comes up or maybe the truck intake?
Old Jan 10, 2009 | 11:11 PM
00ChevyScott's Avatar
Wearin' da big hat
This was on a different dyno, so it might be set up differently than the other one.
Old Jan 11, 2009 | 02:19 PM
BlackGMC's Avatar
Resident Retard
Good to meet you too! I grew up on carbs and SB fords, so it took awhile to get used to EFI and LSX type motors...
Both runs were with the cutout open, it might be in the tunning, this is my reason for thinking this...
I am basically runing the same timing as previous dyno run... However I am getting more grams/cyl than i was before, roughly .05-.06 in the higher RPM, and alot more in the lower rpm (probably the reason the cam has alot more mid range), see pics below to compare... So IMO i need to lower my timing down to compensate for more air being injested by the engine... Also if you look at the log i started getting some KR at 5200+, thus another reason to lower the timing back down...
Previous setup Grams/Cyl map
Current setup Grams/Cyl map
Also i was commanding a leaner mixture than i was on the the latest run...
So IMO lowering the timing down 2* and leaning it out might have some affect... Eventually after i swap out heads I am going to rent some dyno time to determine all this...
Old Mar 25, 2009 | 10:39 PM
NegraRCSB2X4auto's Avatar
could it be that your flowing better so your compression is not as high. causeing the loss of tq. IDK just thinking out loud. good numbers let's the track numbers now.
Old Mar 25, 2009 | 10:42 PM
Wearin' da big hat
lmao, this is an old thread man
Old Mar 26, 2009 | 12:01 PM
BlackGMC's Avatar
Resident Retard
I dunno, honestly i think the cam was too big for my setup and that is why i lost TQ, basically turned my truck into a rice mobile...
But
my 60ft got better but i have never been able to beat my best time with my old cam... The truck is alot funner to drive with the new cam.. I have a custom grind cam sitting on the bench that will be going in shortly so hopefully 3rd times a charm for cam swaps.
Old Mar 26, 2009 | 01:05 PM
NGA PLZ's Avatar
so the new cam gave up 14lb/ft for 13 extra whp. Awesome numbers for a 4.8 though!
Old Mar 26, 2009 | 01:08 PM
dlt76028's Avatar
this is a couple months old, this is his second cam. the third is waiting to go in
