Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
Low boosted LQ4 numbers
Old Sep 28, 2009 | 06:45 PM
sowaidi's Avatar
Default Low boosted LQ4 numbers
i dont have the sheet but the a/f was alright stayed around 10-11 when boosted.
DynoDynamics
Max Power: 364fwhp 294 rwhp
Max Torque: 380fwtq
temperature: 104F Humidity: 75%
Stock LQ4+cam+sts at 6 psi
i certainly don't like the numbers, i dont know if the truck needs a retune or has somethiing wrong with it. it was dynoed with a quiet summit muffler. the cuout wasnt working but i think with the cuout open it would give~20hp.
Old Sep 28, 2009 | 06:48 PM
norris_83's Avatar
that does seem very low, specially for the boost #'s
Old Sep 28, 2009 | 07:08 PM
charcold-bowtie's Avatar
Seems really low. But not sure how dynosynamics read.
Old Sep 28, 2009 | 07:27 PM
JennaBear's Avatar
Truck Sponsor
DynoDynamics won't show you the inflated numbers that the DynoJets will. On a DynoJet you would have about 450ft-lbs of TQ, basically just add 20% to your numbers to compare.
Old Sep 28, 2009 | 07:37 PM
sowaidi's Avatar
but dont you think its very low for a turbo
Old Sep 28, 2009 | 07:39 PM
JennaBear's Avatar
Truck Sponsor
It might be a little on the low side, but still not bad numbers.
Old Sep 28, 2009 | 08:49 PM
nonnieselman's Avatar
my stock LQ4/80E made 377rwhp and 435rwtq on 6psi on a dyno dynamics with a 60mm turbo and a 22" magnaflow after the turbo.
16* timing 11.2afr
Old Sep 28, 2009 | 10:05 PM
sowaidi's Avatar
what would you think is the problem, tuning maybe? mine also has the 60-1 turbo. LQ4/T56 which i think should give more hp than autos
Old Sep 28, 2009 | 10:09 PM
could all be in the tuning... and i see its 104* ambient... what were your IATs and how much timing is being pulled with the IATs rise?
Old Sep 29, 2009 | 05:21 PM
sowaidi's Avatar
i didnt get to check the timing and the dyno guy wasnt my tuner
