Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
hp gains??
Old Aug 7, 2008 | 04:52 PM
closet red neck's Avatar
I'm not the fastest or make the most HP and TQ numbers but the truck runs pretty good for what it is.......390hp and 385ftlbs N/A to the ground in 82 degree weather. I should hit well over 400hp and possibly over 400ftlbs in cooler weather. My best is a 1.70 60'......
James
Old Aug 8, 2008 | 01:36 AM
Spoolin's Avatar
GFYS and STFU
Originally Posted by closet red neck
Are you asking me.....???????
James
I think it's more on the housing than anything.......the billet front hub, smaller internals..........I'm not sure on the inner workings of the converter. I just know that when you loose some of the rotating mass, your truck will get faster on the big end, more power on the dyno and laungh harder out of the hole.
James
Yeah I was, didn't know there was that big of a difference in weight between the stock and aftermarket converters! I'm aware of the whole rotating mass sucking power just wasn't sure how much weight savings is seen from the actual rotating mass of the converter. I would imagine that most of that added weight of the stock verter is in the housing and the stator but I'm not converter expert so I don't know. But your right in you'll gain a little something something, same as when you get lighter wheels for a vehicle.
Old Aug 8, 2008 | 04:51 PM
ls1klr97's Avatar
weighed mt 9.5 stall came in at 31 lbs full of fluid then weighed my stocker and came in at 56lbs full of fluid didnt know it would be much of a difference!!
Old Aug 8, 2008 | 07:55 PM
Oh yeah, then add in stuff like billet yokes(slip & pinion), light weight driveshaft and aluminum flexplate..........free hp.....
James
zblee
Nov 11, 2015 12:41 AM
91LT16SpeedFormula
Oct 1, 2015 08:57 AM
ClintBeastwood
11
Sep 13, 2015 11:49 PM
bisqikss
Sep 8, 2015 03:35 AM
