Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
"DYNO TRUCK LIST" (DTL)
Old Jan 20, 2009 | 12:18 PM
  #261
trever1t's Avatar
2nd fastest 5.3 ECSB
Originally Posted by trever1t
i think you missed a few .....
Old Jan 20, 2009 | 01:26 PM
  #262
GMCtrk's Avatar
This is just a 5.3L with a 112 on it???? 510lbft @ 3000 rpm??!!!! lord jeebus.
Old Jan 20, 2009 | 02:33 PM
  #263
zippy's Avatar
Nitrous helps that left side.
Old Jan 20, 2009 | 02:51 PM
  #264
trever1t's Avatar
lol..yeah just a little. The upper graph is without and the lower is with a 75 shot although the bottle was mosly air.
Old Jan 20, 2009 | 02:52 PM
  #265
moregrip's Avatar
what a rush!
read the first post spivey!
Old Jan 20, 2009 | 02:56 PM
  #266
trever1t's Avatar
Spivey is it now, arggh mately, I'll comply with yee then [my best pirate voice]
I'll take the numbers without the nitrous then, ok?
YEAR: 2005
MAKE: GMC
MODEL: 1500
BODY: ECSB
ENGINE: 5.3L
TRANNY: 4L60E
DRIVE: 4WD
MODS: MP112
LOCKED OR NOT: Locked
CORRECTION FACTOR: SAE
DYNO: DynoPack
DATE: 7/24/2008
HP: 540
TQ: 549
Update
Jeesh!
Old Jan 21, 2009 | 07:48 PM
  #267
moregrip's Avatar
what a rush!
Originally Posted by speeedo
z71 2000
-strocker 408 (11:* compression )
-Chevy 6.0 Iron Block
-Callies CompStar Crankshaft 4"
-Diamond Pistons Flat 4.030 bore -2cc
-Eagle Connecting Rods (6.125")
-ARP Head Studs
-Cometic head gasket
-Patriot Performance GM LQ9 Stage III Cylinder Heads
-Cam Magic Stick V.3 237/242 603/609 113 Lsa
-SLP Performance Crank Under Drive Pulley
-Pacesetter 3" QuickTrip Long Tube Headers + Y-pipe
-92 Fast intake
-92 Fast tb
-afe air intake
-COMP Cams Timing Chain and Gear Set, Double Roller, Bilet Steel Sprockets
-4L60E tranny stock with a transgo kit+tranny fluid cooler
-Dhm E-cutouts 3"
-Msd 8.5mm spark wires
-NGK TR6
-TnT EFI wet kit
-SLP 160* T-Stat
-DYNO: Dynojet
-DATE: 11/17/2008
-HP: 545
-TQ: 543
missing alot of required info
Old Jan 29, 2009 | 09:48 PM
  #268
Danville Performance's Avatar
Originally Posted by moregrip
DTL updated!!!!!!!!!!
YOU ARE THE MAN!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!Thank You
But now I need to update it agian..... I will get you the new info tomorrow. How about 908rwhp-16xxftlbs on #2 Diesel only with a single 3" turbo...
Old Jan 30, 2009 | 11:13 AM
  #269
zippy's Avatar
Sounds like alot of boost.
Old Jan 30, 2009 | 08:02 PM
  #270
Default Not as much as you would think!
45-50psi is what it is running now with the bigger charger. It was in the 850rwhp range with a A5K at 60psi. Pretty cool when you can drop the boost and pick up 50+hp!
