Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
Any idea of HP/ TQ #'s
Old Jan 18, 2011 | 07:01 PM
Petey62782's Avatar
MASS seller approved
Default Any idea of HP/ TQ #'s
I have a 6000 lbs avalanche with a LQ-9 with dynatech long tubes and high flow catted y pipe, trick flow UD pully, flexalite 282 twin monster fans, K&N intake, BBK 80 mm TB , Gibson cat back dual, 160 stat , FLT 4L65 LVL 5 with a yank 2600 stall, 410 gears W/ a eaton posi,and a Nelson tune. I never got it to a dyno so I was wondering if any one with a similar set up or if someone has a good geuss on what #' I might be making so I'm not surprised when I can find a dyno to check. Also i still have the stock injectors that came with the LQ-9 do you think I'm losing anything from having the stock ones or could I gain anything from bigger injectors?
Old Jan 18, 2011 | 07:57 PM
08cheyennesc's Avatar
What size tire? That will make a difference at the dyno too.
Old Jan 18, 2011 | 08:01 PM
Petey62782's Avatar
265/70/17 winter 305/40/22 summer what would be better for the dyno both are soft rubber high speed tires
Old Jan 19, 2011 | 01:44 PM
Petey62782's Avatar
Any guesses ?
Old Jan 19, 2011 | 02:43 PM
dlt76028's Avatar
330 hp
Old Jan 21, 2011 | 02:45 AM
1SlowHoe's Avatar
Destroyer of Transmissions
Don't be shocked when it seems low. My 5.3 with mods close to yours made 236hp/284tq. So figure whatever the extra power the 6L gives and add it on. I'm gonna guess under 300.
Smaller/lighter tires will show better numbers on the dyno.
Larger injectors have no performance value. They just provide more fuel when you build your engine past the point the stock injectors can support. A 250hp truck can swap to 96 pound injectors (and tune for them) and it's still gonna have 250hp.
Old Jan 21, 2011 | 11:34 AM
Petey62782's Avatar
Thanx for the good info
calsdad
Jun 14, 2023 11:07 PM
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
00loudchevy
Dec 3, 2015 05:54 PM
Wrecker 426
Sep 30, 2015 09:39 PM
Cammed4ever
Sep 30, 2015 03:38 PM
