Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
6.0 mp112 Meth dyno tune
Old Feb 18, 2008 | 09:18 PM
BlackSSS's Avatar
Default 6.0 mp112 Meth dyno tune
Dynoed tuned my truck this weeken and came up with 40 more rwhp than last time after meth install and 5 more degrees of timing. Which is probably more like 50 more rwhp because my baseline this time was 10rwhp less than last time with the stock 20s. I now have heavy *** chrome 22s and that is surely the diff. My origoinal 455rwhp came from a different dyno than my tuner's dyno. His dyno reads 10% lower than all other dynos around here (only 2 more). No matter what happens this is true on every vehicle that dynos on both. So unofficially I have 495 rwhp(damnit thats close ) and 512 tq by adding what I gained to my origional best. But like I said its "onofficial" to me until I have a graph that says so. So I am going to the superflow dyno tommorow to get an accurate reading with graph and stock wheels. I am confident that I am putting over 500whp now : ) OFFICIAL results tommorow! Oh yeah still running through stock UNLOCKED converter
And btw: I am sure most of you FI guys know, but if not....Get Methanol injection...IT WORKS!!! Not only ~50 rwhp in my case, but now have a very nice 11.4-11.7 AF readout with only 87% DC instead of the sometimes 12.5 and 100% DC before the meth.
Last edited by BlackSSS; Feb 20, 2008 at 06:15 PM. Reason: one sentence unfinished
Old Feb 18, 2008 | 09:20 PM
joshua022's Avatar
nice, hope you get what your hoping for tommorrow!
Old Feb 18, 2008 | 09:23 PM
BlackSSS's Avatar
yeah I am pretty confident with all things considered
Thanks
Old Feb 18, 2008 | 10:20 PM
stock48's Avatar
9 Second Truck Club
Good luck! Im sure you will get your 500+. I would throw a big bag of ice on that charger, and make sure your Diff, trans, and T case are all up to temp.
Old Feb 18, 2008 | 10:58 PM
BlackSSS's Avatar
yeah its about a 30 mion drive so things should be good and warm : )
Old Feb 19, 2008 | 12:17 AM
maddboost's Avatar
What was the temperature outside when you had it dynoed last time vs this time?
Old Feb 19, 2008 | 10:09 AM
BlackSSS's Avatar
it was in the low 40s last time and 53 degrees this time....which doesn't really matter due to the CF
Old Feb 19, 2008 | 03:06 PM
03sierraslt's Avatar
You are running STOCK injectors? Or stock Radix Injectors (43lb)?
Old Feb 19, 2008 | 05:55 PM
krambo's Avatar
Nice work! Go get that 500/500. Just for reference, I was at 99-100% IDC on the radix injectors with 60/40 meth/H2O and about 62 psi on the fuel. This was running 11.9AFR
Old Feb 19, 2008 | 06:26 PM
Thats my point, there is no way he is still running stock injectors....
