408 Dyno = Low Numbers
dont feel bad man , my truck only put down 600 rwhp with 10 psi and spray but that . i know it has alot more than that , the tune is what i really wanted out of it.
i just dont know why my truck could only make that much boost. after making 15 psi easily before then after i left it still wouldnt make more than 10 psi. swithced back to a 3.0 from a 2.7 pulley and boom right back up to 14 psi.
sorry for the hi jack , but that dyno is putting down lower numbers than what are normally posted on this forum.
sorry
sorry
Something has to be wrong with my setup I just don't know what.
I am thinking I am down between 50-100 hp from where it should be.
9 Second Truck Club
Those dynos usually read way low, just run it at the track ASAP befor you make any rash decisions. Track #'s are all that matters any way. 15PSI reliably on 9.5:1 is pushing it, without race gas, or E85. About 12 is all I would go on 91. If you want 15PSI I keep it at 9 or below.
me and justin were talking about it and I think your cam and your cr is really holding you back. I had a much bigger cam and full exhaust and i could only run a 13.5 at the track which is not much better than my old 6.0.
How long before you put the sts on it? if its going to be a while then i would get some stock zo6 or ls2 heads. and that will bump up the cr to the 9s.
I looked at an online cr calculator and got the following results:
Current setup:
WCCH P&P 6.0 heads(73.5 cc) = 8.7 cr
Swapping Heads to:
Stock LS7(70 cc) = 9.03 cr
P&P LS6(69 cc) = 9.10 cr
Edelbrock 245/215(66 cc) = 9.35 cr
AFR 225(62 cc) = 9.69 cr
Also, changing to a Z06 or similar cam for now might be good. Plus I have head that the Z06 cam is ok for boost.
Current setup:
Swapping Heads to:
Not sure why anyone would care what their motor makes without the FI option if it was built for that. That is pretty much asking to let yourself down. If you figure out all the things that will be happening in the design of your plan with the FI, then most of those things change when you run it without the FI. So dont get so down on yourself. Only be disapointed if your combo does not do well once you have put the FI on it. Then you can compare to what your goals where.
I would not expect some of the motors I built to make much power without their turbos on them, but once you put some boost on it, they make crazy power.
Rick
Rick
Rick
Rick
4xx na that is a good base for making close to 1k rwhp when you crank it. at the 250rwhp level hes at now i would expect that out of a baby motor...
