Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
4.8 Turbo, Ls6 Cam Results
Old Jun 15, 2010 | 04:23 PM
03 True Fire's Avatar
damn good numbers!
Old Jun 17, 2010 | 08:41 PM
ShredSled's Avatar
excellent!
Old Jun 17, 2010 | 08:54 PM
2005 Silverado's Avatar
SPAM HUNTER
Originally Posted by foose04
Thanks guys. I think with another 5psi she would break the 600HP mark. Think the stock head studs will put up with 15psi/600hp? After that, I'm pulling the crap 5-speed. Either going with a t56 or 4l80e.
ill let you know in a month or so how i like a turbo and 4l80e...80e replaces the nv3500 this weekend. Most of the turbo parts should be here soon and the rest when the 80e swap is all done.
Old Jun 19, 2010 | 12:43 PM
foose04's Avatar
Thanks guys. Sounds good 05Silverado, what all you installing to make that 4l80e work? You going to run a stock unit or rebuilt with upgrades?
Old Jun 20, 2010 | 04:32 PM
Team Paulie's Avatar
Registered User
This is all on a STOCK bottom end?
Old Jun 20, 2010 | 09:03 PM
foose04's Avatar
Yes Sir, about 5k boosted miles so far. 80,000 total on the engine.
Old Jun 21, 2010 | 12:19 AM
SPAM HUNTER
Its a built unit, Hughes "racing" rebuild kit with upgraded clutches and koleen steels, hd-2 kit, hd sprag, converter will be a loose GM high stall rated for about 2500 rpm built by roadrunner converter.
Once its in i am going to get it broke in, i dont drive my **** like i stole it until its got a few heat cycles and miles on the stuff. Then once i have it shifting good it turbo time i have alot of parts for that coming to...i was going to wait until fall...but why not just get it done and recoup the wallet later
No E85 fuel system for me though...so i wont be seeing 500+ HP especially through a 80e
Old Jun 21, 2010 | 07:36 AM
Sc00by's Avatar
WOW! Great numbers! I love how the LS's love boost. I want a turbo so I can play too
Old Jun 21, 2010 | 11:36 AM
ducky's Avatar
bitchin numbers. Im dailying MT drag radials on my truck and they have good street manners, and hook just fine, and I made a tad more power then you did. Im sure the nittos will do just fine
Old Jul 2, 2010 | 02:15 AM
foose04's Avatar
Well, I've installed another walbro 255 and stronger wastegate spring. Next question, find another dyno jet or go back to the mustang dyno and try to pull around 550HP.
