Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
4.8 dyno 340/370
Old Jan 28, 2009 | 05:44 PM
jkru617's Avatar
Yeah it was ARD. But he didnt blow my engine yet..... Stewart was tellin me about your truck today.
Old Jan 28, 2009 | 06:57 PM
zippy's Avatar
A stock fuel pump should be good to well over 400RWHP. You may have a week pump, but I would bet there to be more problems than that. What was the fuel pressure? I assume before he told you that the fuel pump was bad he actually checked it. What year is the truck?
Old Jan 28, 2009 | 07:46 PM
jkru617's Avatar
Its a 2003. I have no idea what the fuel pressure was. Stock fuel pump is good even with FI? What other problems could there be?
Old Jan 28, 2009 | 08:09 PM
ou812sm's Avatar
what mods do you have do you have to get that out of a 4.8
Old Jan 28, 2009 | 08:11 PM
jkru617's Avatar
I have a volant ram air intake, Pacesetter LT to a y-pipe, vortech v2 supercharger w/o aftercooler, 42#injectors, and a tune.
Old Jan 28, 2009 | 08:23 PM
zippy's Avatar
The stock fuel pump isn't the best way to go, but I've worked on many 6.0L's running the stock pump with a Radix. Not on max effort trucks, but either way they made alot more power than you're seeing. Right now you're making the power a good cammed 6.0L makes with bolt on's. This is why I ask, did he check fuel pressure or is he guessing? How is the fuel filter? Pressure regulator? I'm not mocking him, but even running it that lean at all makes you question something.
Old Jan 28, 2009 | 08:33 PM
jkru617's Avatar
Yeah I understand your questioning, makes me wonder why I didnt ask more. He didnt do any testing. Just said it was the pump but sounded sure about it. I know a few people making over 400 and the stock pump is fine too. I should check all that stuff before I just assume. But I figure if or when I swich to a bigger motor, a bigger fuel pump wouldnt hurt.
Old Feb 5, 2009 | 01:13 PM
hellbents10's Avatar
LS1Tech Sponsor
Might not even be coming into PE.
Old Feb 14, 2009 | 02:30 PM
jkru617's Avatar
Put on the walbro 255, made 380hp 380 tq. afr around 11.9
Old Feb 14, 2009 | 02:54 PM
03sierraslt's Avatar
How much boost are you running?
