Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
300hp RWHP "SAE"
Old May 10, 2009 | 12:56 PM
  #21
therock's Avatar
Dynojet inflated numbers? I knoiw my Dynojet shop has a loaded setup using a brake of sorts. Maybe some Dynojet models are unloaded and not all?
I know some NASCAR teams in the Atlanta area use this same shop. I thaught Mustang dynos were the one that read more then the standard. Only by what I read here and there anyway. I'm no dynomometer expert.
Old May 10, 2009 | 01:30 PM
  #22
blackbeast ss's Avatar
yes inflated numbers... some dyno jets have a simulated brake not an actual load but the majority of the dyno jet dont have the simulated brake..
Old May 10, 2009 | 04:12 PM
  #23
mred's Avatar
"simulated brake"
so now we run with the e-brake on, up and down the road?
so with the e-brake on,this would a real world feeling?
"WOW" i have a lot to learn
Old May 10, 2009 | 04:15 PM
  #24
therock's Avatar
Blahh! I know these guys at this Dyno shop aint gonna go foe no bull $hit numbers. Too many pros use them for this kind of BS.
Old May 10, 2009 | 04:16 PM
  #25
trever1t's Avatar
2nd fastest 5.3 ECSB
First of all, every dyno reads a little different and then there is "correction" to deal with as well.
Second, a dyno is a tuning tool, used to measure gains (or losses) from modifications or tuning.
The true measure of power is done on the street or the track
Old May 10, 2009 | 04:24 PM
  #26
mred's Avatar
i concur totally. my initial tune was to lean so we put it on the "mustang chassis dyno" to read the A/F. i really could careless about numbers really.
i have seen a dyno run that said a 5.90 car only made 300hp to the rear
i was hoping for a 5.90 in my daily "truck" too LOLOLOL
Old May 10, 2009 | 05:14 PM
  #27
viciousknid's Avatar
Where's the Beef?
Originally Posted by mred
"simulated brake"
The dyno jet with simulated brake is meant to apply a brake to the dyno so that it creates a load on your engine. Otherwise it's like jacking your truck off the ground and seeing how you without a load.
A mustang dyno has a certain amount of resistance that simulates real time driving by not making the rollers easy as easy to spin, Because of this, A mustang dyno usually shows lower numbers than Dynojet.
And yes, all manufacturer hp/tq ratings are at the flywheel.
Old May 10, 2009 | 05:38 PM
  #28
finally someone that actually understands what i was saying... and understands the differences between dynometers
Old May 10, 2009 | 05:53 PM
  #29
mred's Avatar
that have always been falsely advertised.
dating as far back as 1967 prolly before then.
Old May 10, 2009 | 05:57 PM
  #30
Where's the Beef?
GM has always under rated their products. no 2 engines are going to be the same so the numbers are just an estimate.
