Drivetrain & Suspension Chassis | Transmission| Driveshaft | Gears/Rear End/Differential | Traction Aids
New rear dif and gears. Check my pattern pls.
Old Jul 14, 2013 | 05:37 PM
rossp's Avatar
Default New rear dif and gears. Check my pattern pls.
Alright guys, this is my first complete rear end rebuild. New eaton dif and a set of richmond 4.10s. Ive got my backlash right at .009. Does this pattern look good? Just looking for some opinions on my pinion depth.
File Type: jpg
File Type: jpg
Old Jul 14, 2013 | 05:38 PM
rossp's Avatar
I meant to post this in the chevy drivetrain forum if a mod would like to move it.
Old Jul 14, 2013 | 05:53 PM
Atomic's Avatar
I have a gauge for that
Responded on FB but I would like it further down the face and more like 0.005-0.007 backlash. Tighten up the BL a shim and it will help with the depth.
Old Jul 14, 2013 | 06:33 PM
rossp's Avatar
I got the backlash down to .006. Here's a few more pics with everything apart.
File Type: jpg
Old Jul 14, 2013 | 08:45 PM
Beatdown Z's Avatar
Laid Back
Can you post pictures of the teeth you coated? The coated teeth "outline" the gear pattern, IMO. It's looking pretty good though.
What size shim do you have in there right now?
Old Jul 14, 2013 | 10:53 PM
rossp's Avatar
Ive already got it all buttoned up. Time definitely wasn't on my side. I ended up reusing the factory pinion shim, which was .032. Made about a 30 mile drive and all seems good. I had an ever so slight whine for the first few miles, but it seemed to go away.
Old Jul 15, 2013 | 05:18 PM
rossp's Avatar
Did some more driving today. Everything seems great except a small whine from 55 to 60ish on acceleration.
Old Jul 26, 2013 | 09:17 AM
axekick's Avatar
I bet it's nothing to worry about. That pattern looks fine to me and .006" is always good. As long as you have enough preload on all the bearings and the bolts are torqued to spec and you break them in properly then they should be ready for whatever you throw at them.
Old Aug 5, 2013 | 05:42 PM
AUTOT3K's Avatar
what gears are you running? (brand)
some have a tendency to whine, regardless of how its set up
Old Aug 6, 2013 | 02:19 PM
Beatdown Z's Avatar
Laid Back
The Richmonds in my work truck whine, but i did put them in when i was 17. haha
