Drivetrain & Suspension Chassis | Transmission| Driveshaft | Gears/Rear End/Differential | Traction Aids
Heater Core...........
Old Nov 5, 2015 | 09:07 AM
Mark Johnson's Avatar
Default Heater Core...........
Hey guys- have a buddy with a Ranger and the heat doesn't work. First thing comes to my mind is heater core plugged up, but is there an actuator to direct coolant to the heater core that could be malfunctioning?
THanks
Old Nov 5, 2015 | 10:36 AM
Atomic's Avatar
I have a gauge for that
If its anything like the silverados (and most cars that I know of), coolant is always being pushed through the heater core, but there is an actuated door in the dash unit to direct the airflow either through the heater core or through the evaporator core (AC).
Old Nov 5, 2015 | 07:58 PM
1FastBrick's Avatar
Custm2500's Rude Friend
My first thought was its a Ford... It can't be fixed...
They even circled the problem and put it on the front grille so you are aware when opening the hood...
Seriously though, if it's an older ranger, Look under the hood and see if it has a recirculation valve on one of the coolant lines going back to the cab through the fire wall.
If that's not it, then it's like Atomic stated above.
Old Nov 5, 2015 | 08:04 PM
Wolftrk99's Avatar
Check the vacuum line going to the coolant valve in the heater hose they like to corrode away and not pull vacuum anymore...
Old Nov 5, 2015 | 08:05 PM
Wolftrk99's Avatar
Heater control valve..... Thats what its called....
Old Nov 5, 2015 | 08:08 PM
Wolftrk99's Avatar
They circled it and highlighted it in blue.... Have you ever noticed that gm is the onky company that hasnt circled theyre logos..... Vw,honda, ford, mercedes, even dodge and chrylser have circled the problems some just try to hide it better!!!
Old Nov 5, 2015 | 08:28 PM
1FastBrick's Avatar
Old Nov 6, 2015 | 10:35 AM
Thanks guys- it's a '94 with a 4 banger. I'm looking to the blend door now as he said that someone like closed some wires every winter; I'm gonna actually see and get to the truck today. Anyways- where would this blend door be located?
Old Nov 6, 2015 | 01:43 PM
Wolftrk99's Avatar
On the heater box under the dash
Wolftrk99's Avatar
Tahts probably all vacuum controlled being that its a 94
