Drivetrain & Suspension Transmission | Gearing | Traction
how to remove a rear half shaft "wheel hub"
Old Mar 18, 2009 | 04:23 PM
ducati748's Avatar
Default how to remove a rear half shaft "wheel hub"
I am just curious how this is done i have already removed calipers and rotors.
any help would be great
Old Mar 18, 2009 | 06:07 PM
KySilverado's Avatar
You have to open up the differential. Remove the carrier pin bolt. Remove the carrier pin. Remove the spider gears. Push the axle you want to remove in toward the carrier, this releases the c-clip in the diff. Remove it and pull the axle out.
OOOOPS, realized this is dodge section Same may still apply.
Old Mar 24, 2009 | 12:11 AM
BlownHD's Avatar
If it is a C-clip axle pretty much everything that KYSilverado said, except you don't always have to remove the spider gears to get the c-clip out, if it is a full floater you need to take all the bolts off holding the hub on at the end and then pull it off.
BoostedBowTie
Jan 3, 2020 06:46 PM
chopperloco
Jul 10, 2016 10:45 PM
DarkhorSe_SS
Aug 20, 2015 08:58 AM
Ketis
Jul 23, 2015 12:37 PM
signguy62
Jul 16, 2015 05:43 PM
