Drivetrain & Suspension Transmission | Gearing | Traction
6 speed Manual in Ram 1500 Hemi
Old Jun 22, 2012 | 12:31 AM
BMEP123's Avatar
Default 6 speed Manual in Ram 1500 Hemi
I would love to have a 6 speed manual in a Ram 1500.
Has anyone done this?
The 05-06 Ram 2500 Hemi came with the G56 6-speed. I test drove a 06 2500 Hemi 6 speed. It's a heavy duty trans but shifts easy enough to be fun to drive. It works good for towing with the extra low gearing in 1st and reverse. Put a Gear Vendors overdrive behind it and split shifts and have a close ratio 10 speed (some overlap, so not really 12 gear ratios) with double overdrive for 1800 rpm 80 mph cruising.
Will the large G56 trans fit in the tunnel area of the 1500?
I don't really need or want all the towing capacity and extra weight of a 2500, but, I really want that manual trans. A 2500 weighs about 600-700 lbs more than a 1500. 2500 Ram Hemi 6 speeds are very rare.
Thanks,
Jim
Old Jun 22, 2012 | 02:55 AM
DR132's Avatar
they made 1500's with 6 speed manuals...
Old Jun 22, 2012 | 11:38 AM
BMEP123's Avatar
A 6 speed manual was not available with the Hemi in a 1500.
The 6 speed was only behind the V6 and 4.7 V8. It was a small light duty trans.
Old Jun 22, 2012 | 04:00 PM
FrostKing's Avatar
Thanks,
Jim
I don't see why it wouldn't fit. The 2500 and 1500 cabs are identical as far as I know. You will need to fabricate the transmission cross-members and driveshaft.
Old Jun 23, 2012 | 03:16 AM
DR132's Avatar
ahh ok.
lsxperformance
Apr 20, 2016 12:17 AM
thewrx
Aug 12, 2015 08:28 PM
Austino
Jul 30, 2015 03:28 PM
Rwilliams85
Jul 14, 2015 04:36 PM
FlowmasterMufflers
Jul 9, 2015 11:35 AM
