TIME SLIP DATABASE
Went to track: Yuck!
Old May 19, 2006 | 07:56 PM
GMC_DUDE's Avatar
Thumbs down Went to track: Yuck!
Went to the track for the first time Wednesday (yes, I played hookey. ). The good news: I beat 2 of the 3 people I was lined up against, and outperformed a Subaru WRX (it had a turbo, I checked). Bad news: My best was still absolutely rotten. Here are the gory details:
R/T: 0.860
60': 2.240
330: 6.186
1/8: 9.494
@MPH: 74.75
1000: 12.341
1/4: 14.823
@MPH: 89.98
This was launching in 4-HI. Launching in 2WD gave me 1/10 longer 60 ft., and 2/10 longer e.t.. Looking at the numbers, I'm guessing the problem is in the 60'. This isn't too surprising as the short-stroked 4.8 has notoriously weak low end torque. Furthermore, the stock converter stalls at only 1600 rpm, and at that point the blower is making 4 psi, some help but not much. To top it off, the pcm is pulling about 19 degrees timing on launch. It looks to me like a 3000 rpm stall converter would help things. Does this sound right or am I off base? Any other ideas or suggestions? I know a 6.0L would fix the problem, but I'd like to stick with the current engine if possible. Thanks in advance for any help or insight you can provide.
Old May 19, 2006 | 08:03 PM
F8L Z71's Avatar
You're having the same problem a lot of us have. The Radix pulling all your timing upon launch and it kills your ET. A stall would help but youre still gonna lag out of thew hole until you get your timing tables worked on so it doesnt pull so much timing.
I just dropped my truck off to have it retuned and a new stall put in so I'll let ya know how it helps me out.
Old May 19, 2006 | 08:24 PM
TURBHOE's Avatar
wow that make me feel better about my 14.85 n/a. good luck its all in the tune lol.
Old May 20, 2006 | 02:32 AM
TravisH's Avatar
sounds like it is in the tune mostly, are you using the stock radix tune?
I bet that stall will get you into the low 1.9 60' range. I was running 2.0 flat, but your truck is lighter and blown.
Old May 21, 2006 | 07:17 PM
GMC_DUDE's Avatar
I think I found the problem. Thanks F8L and Travis for pointing me in the right direction, and thanks to the Search button for fetching me the details.
ZQ8Dude
Aug 5, 2009 10:05 PM
02Denali6L
Jun 3, 2008 06:16 AM
outlawz2004
Apr 18, 2008 10:24 PM
02Denali6L
Mar 12, 2008 07:22 PM
