TIME SLIP DATABASE
went to the track and not happy
Old Oct 8, 2009 | 05:37 PM
skeet's Avatar
Originally Posted by Most Hated
got the new cam installed and tuned , a/f is around 11.5-7 the truck felt good till i made it a dual 3" xpipe with 2 magnaflows and the truck felt weak, i thought it was just me , well took it to the track yesterday 12.1@112mph with a 1.77 60ft , that was best all motor .then gave it a 100 shot nos pass 11.6@120mph 60ft was 1.74 , same times as the gt2-3, what can be wrong ? do yall think the exhaust is killing me?
old cam gt2-3 207/220 570/575 118lsa
newcam patrick g spec 231/247 617/623 115lsa
dunno if the STS and dual exhaust is the perfect setup, but i can say i run a 170-172 60 since i changed to the bogarts and run NA times of 12.1x being my best at 110 mph and that was on a humid night. i run a dual exhaust No X pipe with 2 borla mufflers.your top end is bad *** from the trap speeds. have you always ran magnaflows? and which ones are they?
if its not that much trouble i would try the Y pipe vs. the dual exhaust
Old Oct 8, 2009 | 05:57 PM
quicksilverado's Avatar
He has a maggie, not a sts.
Old Oct 8, 2009 | 06:01 PM
Most Hated's Avatar
Originally Posted by Snacktime
No cam expert but it looks like you went from one end of the spectrum to the other.
Can you post full slips? Final ETA doesn't show if you moved the power band or if there is another issue.
the only diff was the cam swap and going from y pipe to x pipe
ok here goes the time slip gt2-3 y-pipe no nos
i1 1.716
i2.000
i37.685
i3mph 89.647mph
e.t 12.072@112.334mph
gt2-3 y pipe 100shot nos
i1 1.717
i2 4.870
i3 7.482
i3mph 93.538
e.t 11.640@120.304mph
ok this time slips are with the new cam xpipe no nos
i1 1.744
i2 5.240
i3 8.010
i3mph 88.858mph
e.t 12.427@112.533mph
i1 1.720
i2 4.979
i3 7.717
i3mph 89.437
e.t 12.142@111.859
new cam xpipe 100 shot nos
i1 1.742
i2 4.877
i3 7.474+
i3mph 93.464
e.t 11.605@120.003
Old Oct 8, 2009 | 06:02 PM
Most Hated's Avatar
Originally Posted by quicksilverado
You are hurting off the line. Take .2 off the 60' and you will pick up about .4 in the et. That would put you in the low 11s, which is where you should be with a 120 mph trap. Are you spinning off the line?
a lil spinning occurs , what concerns me more is the no nos times
Old Oct 8, 2009 | 06:05 PM
Most Hated's Avatar
yup its a maggie and im thinking of trying the y pipe swap to see if theres a diff
Old Oct 8, 2009 | 06:06 PM
SincalT/A's Avatar
What rear gears?
This is a 2wd rcsb correct.
Old Oct 8, 2009 | 06:45 PM
skyhighsami's Avatar
no title here
What was the temp difference? Though with the nitrous it shouldn't matter so much about heat.
Old Oct 8, 2009 | 07:14 PM
Cuerva's Avatar
11 Second Truck Club
Looks like you had a better driver last time LOL. Go back to "Y" pipe and single 3" exhaust and just play with your suspension. Truck should easily dip into the 11's without the juice. When was it sprayed this time? If my memory serves me right, I sprayed her right around the 60' mark, right where it started hooking.
Old Oct 8, 2009 | 07:46 PM
Most Hated's Avatar
this was sprayed just right after the line , and bout the temps they weren't that much of a diff
Old Oct 8, 2009 | 07:52 PM
Most Hated's Avatar
Originally Posted by SincalT/A
What rear gears?
yes and 3.73s
