Went to the track last night,
What was the temp on your 12 sec pass vs the temp at the track yesterday???
I'm going to go with weather you guys had a high yesterday of 97 degrees and over 60% humidity.... try correcting your times in the below site and see if that 13.88 comes down a bit. 20 degrees of dry heat is good for 3 tenths in my truck on the same day.
http://www.weather.com/weather/pastw...=0&when=050207
http://www.csgnetwork.com/relhumhpcalc.html
1slow01Z71 gave you some good advise with the leak down test. If you were having transmission problems I'd expect a bigger drop in your MPH. Your pushing 97 mph on your 13.8 run only 8 mph diff between your best run.
Jeff
Jeff
well this case the 12 was in washington state where it's not humide like here and the temps were at 60-65*'s but i ran my truck about 3weeks with stock stall and it was like 85 or something like that and ran a 60ft@1.87 and a 13.19@102mph
when i moved here last year in july from washington state, i think in october when i still had the tbstall my best run was a 13.56@98mph, and this was sdtune and meth (just washerfluid for cooling effects) and i was running 13lbs of boost and 12*'s of timing if i didnt have the tbstall at that time i'd probably would've seen high 12's
i'll go back to stock stall, and work my way from there, im going to put on a cam, which one i dont know, i wanted the lpe gt2-3, but i think there is a better one for the radix, and springs as well
I run mid/low 14's during the winter and climb up to low 15s during the Arizona summer.
Jeff
