TIME SLIP DATABASE
Went back to the track...
Old Apr 4, 2009 | 10:41 PM
JoeGibbSilverado's Avatar
Default Went back to the track...
This time i went with radials, they are 275-60-15, 28" diameter, last time i ran, 15.549 on 20's, spun, this time on radials, dead hook, still a 2.1 60', and got a 14.516@92.87, 1/8TH mile was a 9.309@77, not bad for my mods i guess, stock tranny, converter, and rear, was really hoping for some lower numbers though. I know its all in the 60', i was sure my 60 would be better with these radials but its not, what gives? and no, its not supercharged, lol
Old Apr 4, 2009 | 10:42 PM
00ChevyScott's Avatar
Wearin' da big hat
You need a converter to see much better 60s than that.
GMCtrk's Avatar
were you able to floor it right off the line?
Old Apr 4, 2009 | 10:47 PM
yep, i tried an idle stomp, and then i foot braked up to 1900, still the same
Old Apr 4, 2009 | 10:50 PM
GMCtrk's Avatar
well in that case you just need more power I guess. The tune is good, that's for sure I know. This is a reg cab or ext. cab? You may want to look into 4.10s and a trutrac.
Old Apr 4, 2009 | 11:01 PM
reg cab, no tailgate, few minor pieces ditched here and there, still pushing 20's up front, yeah i want some 4:10's, need to ditch these gibbs 20's
Old Apr 5, 2009 | 07:23 AM
bluecajun5.3's Avatar
11 Second Truck Club
how was the weather?
something ain't right some wheres. you should be running close to 14.00's around 95-96.
Old Apr 5, 2009 | 09:08 AM
O-FiveCC's Avatar
Still good numbers man!! Get those 20's off the front and drop another couple tenths. The DA plays a huge role too. Do you know the temp and humidity level?
Old Apr 5, 2009 | 07:02 PM
it was around 65-70 degrees out, dont know the humidity, guess i need a log cable from charlie, and let him make some adjustments, truck should have picked up more
Old Apr 5, 2009 | 07:45 PM
also, i ran in reg mode, then in tow haul wich is now my performance mode, same time, atleast i was consistent last night
