TIME SLIP DATABASE
Weight reduction list?
Old Jan 23, 2024 | 11:49 AM
10 Second Club
Originally Posted by terravast4
Work on that 60ft time. You should be able to run a 12.80
It needs a converter, BAD. Current one barely flashes to 1800 RPM. Just bought an FTI 3200, hopefully that solves it.
Old Aug 20, 2024 | 05:52 PM
10 Second Club
Recently ditched the front sway bar, 24.2 lb weight loss total. (Bar, brackets, bushings, hardware)
I've got to be close to 250lbs off of the truck. I ditched another 5-6lbs a few months back.
Old Sep 2, 2024 | 09:50 PM
BLCKEND's Avatar
I have gone from 5300 to 4500 doing what you’re doing. Just pulling **** off as I go and see things that aren’t needed. The biggest one for me was tires. Went from a 305/50/20 to a 275/55/17 on Yukon wheels and gained .5 the exact same night only tuning for tire size change.
Old Nov 15, 2024 | 01:20 PM
10 Second Club
I ditched the overload leafs today - 31.8lbs
Also got rid of my air lift helper bags - 12.8lbs
Hopefully the truck will actually weight transfer now with the combination of removing that stuff and Viking double adjustable shocks up front.
Old Nov 15, 2024 | 05:59 PM
Fullpower's Avatar
Let your Wife drive?
Old Nov 19, 2024 | 12:46 AM
BLCKEND's Avatar
I did this(not including bags) hoping for the same and didn’t get much. It helped a little bit, but noticed if I do spin it just makes the front spin worst than before.
Old Nov 19, 2024 | 03:18 PM
10 Second Club
I had no problems hooking up last Friday night. But, definitely going to have to play with the front shocks more. Watching the two passes, the nose jumps up and settles down rather quickly.
Old Nov 19, 2024 | 06:47 PM
BLCKEND's Avatar
yea I think I need a better tire. Once I start spinning I spin most of 1st gear. I also want to relocate my rear shock both being behind the axle.
Old Nov 20, 2024 | 05:48 AM
10 Second Club
What tire are you running? I'm on a 315/50r17 MT radial pro. They work, but I am working on switching to a 15" wheel and a 295/65r15. Rear shock relocation is on the list as well. I currently have Bilstien 5100s with Belltech shock extenders. Not exactly a drag race setup.
I'm putting together an LQ9 for the truck, wish I had been able to find an aluminum block that wasn't 4-5 times the cost. I'd like that weight off of the nose.
Old Nov 21, 2024 | 10:55 AM
BLCKEND's Avatar
I don’t have anything special. I’m just getting to the point where tire matters only on the streets. It’s a weird size 255/55/17 I think? Just wanted a short tire.
mines a stock LQ9. Would love to build an aluminum block as well. An extra 100 off the truck would be nice. That would get me below 4250!
