TIME SLIP DATABASE
Very disappointed
Old Jul 24, 2010 | 03:59 PM
KDavis04ss's Avatar
Originally Posted by iamkeniff
Circle D 3200 (reworked 278mm) tell Chris to make it as loose as he can bc mine flashes 3400ish behind a 500 flywheel hp motor
Thats the converter i have. how much does it cost to send it back and have him do that?
Old Jul 24, 2010 | 04:03 PM
iamkeniff's Avatar
then you have the tighter converter. mine brake stalled to a 3200 with a stock 5.3 in my CC. have you tried to flat foot it?
whats your exact cam specs?
you may need to just upgrade to a 3400 or a 3600 converter.
Old Jul 24, 2010 | 04:15 PM
custm2500's Avatar
Ph.D. in HUBRIS
You are running the 1/8th so too big of cam and too small of a converter is going to kill you because the cam would show on the big end.
Old Jul 24, 2010 | 04:21 PM
iamkeniff's Avatar
plus you need the converter to help get to the sweat spot of the cam to get the truck moving.
my 60' didnt change at all even with a gear swap. my cam makes power at about 3400ish which is the need for a 3600 to help it start pulling. we'll see though.
Old Jul 24, 2010 | 04:36 PM
KDavis04ss's Avatar
iv never tried to flat foot it. its the tsp 228 228 588 588 lift on a 111lsa. i would love to have the circle d 3600 but would it actually stall to 3600? and how much of a difference would it actually make?
Old Jul 24, 2010 | 05:20 PM
iamkeniff's Avatar
that cam requires a 3400 converter or bigger. what its going to do is get your cam into the sweet spot on the take off and allow the motor to start pulling on the launch vs roll a few feet then take off ya know? that 3600 should foot brake to 3500-3600 but it could probably flat foot looser which wont hurt you at the truck honestly.
let some of converter guys chime in, im still learning. all i now is with a big cam like that the 3400-3600 would work best for you.
Old Jul 24, 2010 | 05:39 PM
GMCtrk's Avatar
I've had about the same experience post cam, but since I've only been on street tires I can't get on the throttle off the line. I noticed a very big difference right off the line between the stock cam and a mid 220s cam, the stock cam hit a lot harder. My stall is a 3600 but it's 10.5" and tight. If you check, most of the people running fast recommend a 4000 plus stall to get off the line and into the cam's powerband fast.
Old Jul 24, 2010 | 06:42 PM
zippy's Avatar
Tuning problem... If you scan the truck and put a wideband on it you'll find the problem. There is no reason with that small of a cam you lost that much low end and since you are still running the same 60', it's not the low end that is the problem either. You have a tuning problem, not a converter problem.
Old Jul 24, 2010 | 07:04 PM
baSICK5.0's Avatar
i was there and watched you run your runs. I can say that the left lane run you spun to 60' easy. you were spinning like hell. the track was crap as it usually is in Douglas.
Old Jul 24, 2010 | 07:37 PM
iamkeniff's Avatar
whats suppose to be adjusted in the tune?
