TIME SLIP DATABASE
Took my '04 Silverado down the track
Old Jan 18, 2010 | 08:54 PM
95 bright teal's Avatar
Originally Posted by 2004SSS
you put a sbc in that thing?
He started with a v6 if you didnt know.
Hey mike do you knw what it weighs?
Old Jan 18, 2010 | 09:03 PM
04SilveradoMykk's Avatar
The truck weights 4,380lbs.
no kidding , way to do something different . whats the specs on the motor? carb or injected?
4.040" bore x 3.48" stroke. 10.7:1 static compression. Patriot heads. Comp XR276HR-10 camshaft.
Old Jan 18, 2010 | 09:06 PM
GMCtrk's Avatar
Well, I completely admire your dedication to the SBC swap, but I'd say you're down at least a solid second to a cammed 6.0 ls.
Old Jan 18, 2010 | 09:09 PM
SLOXCAB's Avatar
wow you dont see that everyday
Old Jan 18, 2010 | 09:13 PM
2005 Silverado's Avatar
SPAM HUNTER
Probably only time i will agree with you...
Im pretty sure he's about 1 second off of a cammed 5.3, sure if he ditches the 22's he could get mid 13's, but thats with a BUILT SBC.
I think ill stick with cathedral port heads on my GEN III truck motors...some of you know why this is funny, but im pretty sure he said..."Those heads work for cars maybe, but not for a truck" when i met him last year.
Ill give you points for originality though.
Old Jan 20, 2010 | 10:01 AM
A cool shot of the cars in the staging lanes, my truck in the center
Running 90lb a piece wheels/tires, with bad traction issues... sure
Old Jan 20, 2010 | 08:03 PM
Here's the times of all five of my passes.
1st pass ever) 14.8 @ 88.8mph, 2.25 60' (Back to the Future, anyone?)
2nd pass) 15.8 @ 88.3mph, 2.42 60' (I just sat & spun tire at the start line)
3rd pass) 14.6 @ 89.3mph, 2.05 60'
4th pass) 14.2 @ 94.6mph, 2.03 60'
5th pass) 14.1 @ 94.6mph, 2.05 60'
With a couple more passes & practice I think I could have broke into the 13's
Old Jan 31, 2010 | 06:08 PM
Here's something interesting... I discovered that my vacuum secondaries weren't opening. Now that it's fixed it's so much quicker... I think all of my previous track runs were made with the secondaries stuck closed.
Yes, I know vac secondaries won't open while reving in the driveway... I actually rigged up a small camcorder focused on the vac pod & linkage, and then went for a drive. The secondaries never opened under any throttle position under any load... and I had the lightest vac spring in the pod too.
Old Jan 31, 2010 | 06:11 PM
pittman's Avatar
Great looking truck !
Pitt
Old Jan 31, 2010 | 06:17 PM
LsxCody's Avatar
nice truck,thats a different setup for sure
