TIME SLIP DATABASE
Thinking about switching to 26" slick, any opinions??
Old Sep 16, 2009 | 06:19 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
well the shorter tire will force you into shifting earlier and lugg across the 1/8th if that is your venue. A taller tire might help if you are really winding it up like that
Old Sep 16, 2009 | 06:22 PM
BlackGMC's Avatar
Resident Retard
Originally Posted by GMCtrk
Do you think this is possible with a 6.0, or only with the 4.8 due to the shorter stroke?
I dunno it is all in the setup... Last time on the dyno, the guy took it up to 7k and it started dropping off around 6700-6800...
Old Sep 16, 2009 | 06:24 PM
GMCtrk's Avatar
I've been told the 230/224 111 in a 6.0 pulls to 6800. Just wondering if taking it to 7k at the track is feasible or not.
BlackGMC's Avatar
Resident Retard
Ya that is why i am asking, i am at that threshold where if went shorter it could actually make me slower...
Old Sep 16, 2009 | 07:20 PM
00ChevyScott's Avatar
Wearin' da big hat
I wouldn't do it. When I ran those 26" drag radials (used and bald but got for cheap) I had some problems with traction and it made the rear want to hop a little. I think you should keep the 28"s
Old Sep 16, 2009 | 07:58 PM
Derek @ EDO's Avatar
FormerVendor
Tractions going to be hard but they will work.
You would have around a 4.42:1 final ratio by swapping.
Old Sep 16, 2009 | 08:27 PM
dlt76028's Avatar
with a little grinding...
http://dallas.craigslist.org/mdf/pts/1362182721.html
Old Sep 16, 2009 | 09:09 PM
bluecajun5.3's Avatar
11 Second Truck Club
Well i rarely get to go to the 1/4 mile track so i am not sure on the rpm... I normally go to the 1/8th and i usually shift a little bit before the traps... So usually i just keep it in 2nd rev up to 7000-7100ish rather than shifting into 3rd...
if that's the case your better off with the tire diameter you have now, maybe even taller will help.
Old Sep 16, 2009 | 09:17 PM
BlackGMC's Avatar
Resident Retard
True but i am wondering if i gain some with the 60ft, wil that offset the loss up top in teh 1/8th?
Old Sep 16, 2009 | 09:21 PM
GMCtrk's Avatar
spin it up to 7200 to offset it
