So close i can taste it!!!
Originally Posted by Linda
The worst that can happen is i blow it up...
.Doubtful. Most engines can run short blips well past "redline" but I dont know enough about the 8.1Ls to know what their springs and such can handle. I mean redline is like 6k on the 5.3L trucks but I used to run mine to 6200 all the time on stock internals
Originally Posted by Norm02
Not trying to hijack the thread, but why did you get rid of the turbo and go to a radix??
I was gonna build a RCSB race truck and put the turbo on it and make the Z71 N/A. Ran across a great deal on the blower so stuck it on the Z71. That's pretty much it. It wasnt a real STS vs Radix choise. Just weird circumstances. Both are great setups and right now I would be hard pressed to choose one over the other.
Originally Posted by DanaliHD
crank up the boost. 5lbs is a joke. very impressive time for such low boost. I say go to at least 8lbs. I ran basically the same times on 15lbs that I did on 12 because of belt slippage.
Jesus! Your running 12lbs of boost with no IC? Do you have any KR/Detonation? How does it perform in the summer in the heat? Ohh, i just saw in your sig you got meth. injection. I would need an IC or Meth to go any higher than 5 or 6 lbs i think.
