So Close!
The truck is pretty close to the car. Maybe next year. I am probably done running for the year since the tracks close early down here. I would like to make a 1/4 mile pass but 3 hours is to far to drive for me.
before I got to test it.
Interesting, that's exactly what I did, except went from the bottom shock bolt to an eye bolt beside the upper shock mount. Do you have any preload on it, or how much slack do you have at resting height? I tried mine with no slack/no preload and it seemed to help it go straight, but still spins pretty bad. Wanted to try a few different ways, but I got the boot, and my trans took a
I have them lowered to sit level with the rear blocks removed. I have a 2" shackle I may add to the rear, then lower the front more to match. You think that would help? I have my premise about the same as yours. I think my little tc76 just spools too fast. If I launch at any boost at all, it wants to get sideways bad, and that's with 285/60/18 kumho stx's which are decently sticky for a street tire. My 11.53 run was with a 2.2x 60'!
Awesome job! Are you running full weight?
Not completely full weight. I run my stock wheels and tires instead of the 20's and remove the easy stuff like bed liner, hitch, tail gate, spare and subs. My race weight is about 5,150 which is about as light as I can get it in under an hour.
Vortec350ss
Jan 12, 2016 10:36 PM
