TIME SLIP DATABASE
The quest for 9s has begun..
Old Oct 20, 2015 | 07:06 PM
03regcab sierra's Avatar
Default The quest for 9s has begun..
Well I've made a lot of improvements on the truck over the year and I've decided to go for gold. This weekend is the last track day of the year for us so I'm going all out.
So far my best has been 10.36@131. I have since then changed a few minor things that hopefully will make a major difference. Truck is making 100rwhp more than it did on the 10.3 pass so if all goes well it should dip into 9s.
Old Oct 20, 2015 | 07:12 PM
fastjweb's Avatar
Good Luck!!!
Old Oct 20, 2015 | 07:15 PM
Vortec350ss's Avatar
Wow! This time of year is exciting for that reason alone! In for results!
Care to share what you changed?
Old Oct 20, 2015 | 07:36 PM
Added a nnbs intake, did a little more Suspension tweaking, and of Coarse turned up the boost to 22psi.
Made 821rwhp/730rwtq
Old Oct 20, 2015 | 07:55 PM
montecarloss's Avatar
LS ADDICT/BUILDER
good luck, what size converter do you have?
Old Oct 20, 2015 | 08:37 PM
walledition's Avatar
good luck man, PEDAL TO THE METAL!!!
Old Oct 20, 2015 | 09:37 PM
Converter is a circle D pro stage 3 258mm 2B
It's about 33-3500 stall. It has been the best working converter I have ever used.
Old Oct 20, 2015 | 09:59 PM
ZO6Ted's Avatar
Sounds like your prepared. Best of luck!
Old Oct 20, 2015 | 10:24 PM
GMCtrk's Avatar
I don't understand how there can be so much variation from converter to converter. That same converter on my setup was a train wreck.
Old Oct 21, 2015 | 07:40 AM
LS ADDICT/BUILDER
I know what you mean, I had a 2c and it would not even build any boost under foot brake. I got it restall and now is a 3b and it feels so much better. anyways good luck man
