TIME SLIP DATABASE
No traction tonight
Old Sep 17, 2006 | 12:04 PM
tarinitup's Avatar
9 Second Truck Club
Default No traction tonight
went to the track last night I couldn't get traction no matter what I tried. 1st run I take off without stalling and spin so bad that I run an 11 on the 1/8. Then I stall it to 1500 after heating up the tires and put the truck on 3rd gear and it spins 3/4 of the track but still gets a 10.2. I got pissed off but decided to do one last run with more weight, less tire pressure and a little nitrous. I loaded up my brother and set my window switch to 4000-5700 so that I wouldn't loose traction I by anychance it hooked with less tire pressure. The last run was 9.37 @ 79 with a 2.4 60 ft time. I am positive that with slicks I will reach my goal of running a 8 sec pass at the 1/8 and 13 sec time slip at the quater.
Old Sep 17, 2006 | 12:18 PM
litreddevil's Avatar
Banned
the best way i found to launch on street tires is stall it to about 2000 and just let off the brake let the truck roll a bit then walk into it hard.i was able to pull a 1.81 60" with toyto proxes 31" tall.
Old Sep 17, 2006 | 11:03 PM
AustinDesigns's Avatar
Hey man, saw your last run! This comin weekend I should have the slicks out there. I want to see what your truck will run with some traction! See ya this weekend. Oh, got the lowering kit on the truck, and it looks sick!!! I'll try to get some pics of it tomorrow to post up on here....
Later
Old Sep 18, 2006 | 05:01 PM
tarinitup's Avatar
9 Second Truck Club
sounds good, I will let you know if by anychance I can't make it out there. Right now it looks like my weekend is clear.
Old Sep 23, 2006 | 12:06 AM
tarinitup's Avatar
9 Second Truck Club
I tried my luck out on the 1/8 again and still the same results even with 15 psi on the tires. Best run was a 9.36 @ 79 with 2.37 60 ft against another member from here that ran a 9.18 @ 77 with a 2.23 60 ft. Gonna start working on traction with some slicks and caltracks.
Vortec350ss
Jan 12, 2016 10:36 PM
bearden86
26
Nov 15, 2015 03:58 PM
shootermwc
Oct 8, 2015 01:45 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
TAPyvehc93
Sep 14, 2015 01:22 PM
