TIME SLIP DATABASE
New times for Stock48 with KBRacing custom PT88 Turbo kit.
Old Apr 3, 2010 | 07:06 PM
dlt76028's Avatar
Originally Posted by kbracing96
The 10.33 was in Cali too, was 10.6 in Colorado I believe. Went from a TC76 turbo to PT88, my pipes with 4" down pipe bumped up the boost and he still thinks there is a low 9 in the truck with better traction and a taller gear. I'll let him give the full report when he gets home, but that is hallin *** for a 4900# truck!
Doesn't get much better then 1.42 60'
Old Apr 3, 2010 | 07:09 PM
kbracing96's Avatar
Except when it starts spinning all 4 after the 60',
Old Apr 3, 2010 | 07:17 PM
skolman91's Avatar
I remember hes got a 370, are the heads and intake stock stuff? also how much boost with old #s and this time?? Def got that thing moving, and a good improvement for just bigger turbo, DP, and pipe change, nice work..
Old Apr 3, 2010 | 07:25 PM
denali_on_26's's Avatar
From: Where our street cars are faster than your racecars..Mississippi
now i am really getting the fever!!
me ans STOCK 48 have the same basic setup other than my truck is 2wd and i have a 408ci his truck is around 4900lbs and mine is around 4300lbs... unless he has aftermarket heads...
Old Apr 3, 2010 | 07:31 PM
TIM Z's Avatar
11 sec. Truck Mod
Damn ....
Old Apr 3, 2010 | 07:50 PM
vschmole's Avatar
Well he has stock intake. Stock TB. Stock 317 heads ported by himself. Stock fuel tank. 4 wore out et streets. Stock computer. With mufflers 3 1/2" exhaust. Horrible track. AFR was 10.8 and 20lbs. of boost. 19 degrees of timing. And remember it's a 4x4. The truck has tons of room for improvement. We will post the videos when we get home.
Old Apr 3, 2010 | 08:26 PM
HOW IN THE WORLD DID IT NOT PUSH WATER OR LIFT THE HEAD @20psi???
i always read 16psi max on stock heads... i need to know the secrets..lol
Old Apr 3, 2010 | 08:34 PM
GMCtrk's Avatar
holy mother of god. Huge props to both stock48 and KB too for building a hell of a turbo kit. I'm not gonna lie, I didn't think the KB kit had the integrity to handle that much power. I was wrong.
Old Apr 3, 2010 | 08:35 PM
skolman91's Avatar
denalion26s from what ive read on here no detonation can take you a long way to keeping the heads on these things when in boost..
i searched but no luck, whats the comp ratio on his 370? and still rocking the small 215/215 cam? should be a statement in itself for all them "small cam haters" out there if you are..
zeake's Avatar
Awesome. My truck has the potential for this. I am pretty much where he started. 76mm turbo and 4 wheels turnin
